I really want to build the great race project but i don't have the necessary chips. Does anyone know where i can get the 7442n?
Thanks, anthony.
question about the 7442n
The 7442n is the same as any 7442 BCD to Decimal Decoder and you can use a 74HC42 BCD to decimal decoder which will do the same thing..
Have you tried EBAY??
Heres a link
http://cgi.ebay.co.uk/74HC42-Semiconduc ... 53d971837a
Heres a link
- decided to stick around...
- Joined: Tue Jun 08, 2010 12:14 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
thanks alot
, do you know if the sn7445n would work to?
http://www.datasheetcatalog.org/datashe ... tkqlpy.pdf
I had a look at the datasheet and unfortunately it doesnt look like it would work.tgraz34 wrote:thanks alot, do you know if the sn7445n would work to?
This is due to the low current capability (1mA max) you need way more than 1mA per output to drive the LED's so unfortunately you will need something that can drive around 25mA per channel rather than just 1.
