Post here to discuss the original 8x8 Game System.
1266:
nodoubtman
Post
by nodoubtman » Wed Feb 22, 2012 3:57 am
Hello! Which 8x8 dot matrix would be good for these projects, would :
http://www.ebay.ca/itm/10pcs-8x8-Dot-Ma ... 35b6bc78b3
would be good?
thank you!
CA or CC ?
thank you all!
marC:)
Post
by bitfogav » Thu Feb 23, 2012 4:14 am
Hi Marc,
Yes those 8x8 led matrix's are what you need, mine are from sure electronics
Post
by brad » Wed Feb 29, 2012 6:07 pm
Those ones will certainly do the job although I do recommend getting the diffused ones. They just look so much nicer.
nodoubtman
Post
by nodoubtman » Sun Mar 04, 2012 2:15 pm
brad wrote:Those ones will certainly do the job although I do recommend getting the diffused ones. They just look so much nicer.
these ones are good ?
http://www.ebay.ca/itm/20x-BULK-LOT-LED ... 27c412765c
thank you!
marC:)
Post
by brad » Thu Mar 08, 2012 7:41 pm
Those ones are the small 2cm x 2cm versions which I am very sure would only be one color (red) as opposed to having red and green in them.
nodoubtman
Post
by nodoubtman » Wed Mar 28, 2012 8:30 am
brad wrote:Those ones are the small 2cm x 2cm versions which I am very sure would only be one color (red) as opposed to having red and green in them.
Hi Brad!
I have just got 8x8 matrix bicolor 3 mm from sure electronic : XSM-D1088BRG, but the only problem that it has 12 pins not 8 pins...
how do i interface them for smiley face animation you have created?
thanks so much!
marC:)
Post
by bitfogav » Wed Mar 28, 2012 8:37 am
Try this topic, you should find what you are looking for here:
viewtopic.php?f=2&t=250
Gavin AKA Bitfogav
1266:
1266:
