Hi Brad,
My POV display is working well but I get a flicker of ~16Hz of the image or text as is moves.
Do this mean I need a faster motor, or can I change the LED on/off times to get rid of the flicker.
How to stop the flicker of the image
Re: How to stop the flicker of the image
Sorry for the late reply.
Basically to stop the flicker - the motor has to be rotating such that it updates the image at at least approx 25 times per second.
It can be a little hard to do this because it gets a little unstable at higher speeds.
- newbie
- Joined: Sat Sep 10, 2011 8:55 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Thanks Brad!
That's okay
