Got my pickit 2 connected today and had some fun
Its an amazing peice of kit. What I've done so far is work out how variables are controlled from a web page then sent to the pic, so for example you can have a form type page that has all the led's on port b selectable through a button type interace on your webpage then submit it and the pic will turn the corresponing led's on or off.
This is done using a standard form handling script in the html file then read in on the pic. You can use standard HTML files too, once ready to be uploaded to the pic you use microchips MPFS2 program and that converts then into a binfile that the chip recognises and displays.
I will put a little vid on you tube of a few simple things I've done, I can see this keeping me busy for a while
edit... I've just added a DynDNS server Brad so if we are both online you can connect to it and control it remotely .. how cool is that, I got my wife to connect from her work PC and have a go ... awesome
