1266:
Post
by Chuckt » Sun Mar 06, 2011 12:16 pm
http://talkingelectronics.com/projects/ ... rCcts.html
Free (Ebook) PDF:
http://talkingelectronics.com/projects/ ... rcuits.pdf
INTRODUCTION
This e-book contains 100 transistor circuits. The second part of this e-book will contain a further 100 circuits.
Most of them can be made with components from your "junk box" and hopefully you can put them together in less than an hour.
The idea of this book is to get you into the fun of putting things together and there's nothing more rewarding than seeing something work.
It's amazing what you can do with a few transistors and some connecting components. And this is the place to start.
Most of the circuits are "stand-alone" and produce a result with as little as 5 components.
Post
by Chuckt » Sun Mar 06, 2011 12:34 pm
Post
by brad » Sun Mar 06, 2011 3:51 pm
I remember buying talking electronics books back in the 1990's filled with good projects based around transistors
1266:
1266:
