Harvard vs Von Neumann architecture
Post by Chuckt » Sun Jan 30, 2011 12:54 am
There are at least two different types of CPU's in terms of how they are laid out from a physical or architecture standpoint. One is referred to as the Harvard architecture and the other one is referred to as the Von Newmann or Princeton architecture. Depending on the processor, microprocessor or CPU, it is possible to have either. I'm not presently able to lecture anyone on the differences but I'm pointing out that they exist and here are the links that give further information. It is important to note that how a processor is made does change how things get done and should change the way we write programs because it is hardware specific.
http://en.wikipedia.org/wiki/Harvard_architecture
http://en.wikipedia.org/wiki/Von_Neumann_architecture
Re: Harvard vs Von Neumann architecture
Post by brad » Sun Jan 30, 2011 6:19 am
I read up on harvard a while ago which is what (from memory) PIC microcontrollers use.
Up until I read that I just thought all cpu's worked basically the same!
Post by Chuckt » Sun Jan 30, 2011 11:54 pm
I think all processors use Von Newman because all instructions are executed sequentially.
In terms of caches, the X86 seems to copy things from the Harvard architecture because it has two (instructions and data). I'm guessing that the Harvard architecture uses a merged address space where it was calculated (theoretical).
Post by brad » Mon Jan 31, 2011 8:46 pm
Here's a great wikipedia article on PIC's
http://en.wikipedia.org/wiki/PIC_microcontroller
