Bitfogavs Rear Vehicle Light Repair
Post by bitfogav » Sun Jul 15, 2012 12:14 am
Hi guys, for awhile now one of my set of led's in my vehicle rear lamps have stopped working, so I thought I would instigate the problem and share what I found here, So I stripped out the pcb board from the rear lamp which included the strip of led's and tested the power and ground supply to the pcb (13volts) all good. :)
So looking closer at the pcb I found a simple circuit which included a regulator and a strip of led's in series, I tested the power output from the pcb regulator to the strip of led's all good and the ground was good, so I knew the regulator must be fine, I made up a simple led tester and tested each led individually in circuit and bingo! found one of the led not working, it was a dry solder joint, resoldered the led pin and repowered the pcb, all working :D its abit hard to see the led's on the pictures but they go just below the top red lamp.
Lamp led's not working:
pcb board:
lamp working:
Re: Bitfogavs Rear Vehicle Light Repair
Post by brad » Sun Jul 15, 2012 9:50 pm
Nice work bitfogav, and thanks for sharing!
It's always great to track down and fix a fault - rather than pay (most probably) multiple hundreds to get someone else to do it...
Post by bitfogav » Sun Jul 15, 2012 10:30 pm
Yes very true Brad or even buy a new unit (Lamp)?! :)
