nodoubtman
by nodoubtman » Fri May 11, 2012 6:00 am
Hi!
I would like to have the full source of santa scrabble for pic16f628a game, or only the .hex file with the pic16f628a firmwire..
http://www.instructables.com/id/Christm ... /?ALLSTEPS
would be great Brad!
thanks so much!
marC:)
by brad » Fri May 11, 2012 8:16 am
Unfortunately I don't have the sourcecode anymore.
I only have the hex file. It is very similar to the great race though if you wanted to have a look at that one.
nodoubtman
by nodoubtman » Fri May 11, 2012 11:58 am
brad wrote:Unfortunately I don't have the sourcecode anymore.
can i burn the .hex into a pic16f628a?
would this work?
thanks!
marC:)
by brad » Fri May 11, 2012 12:18 pm
Unfortunately not. The 628a / 648a chips don't have enough I/O ports to make it work.
nodoubtman
by nodoubtman » Fri May 11, 2012 12:27 pm
brad wrote:Unfortunately not. The 628a / 648a chips don't have enough I/O ports to make it work.
i think i have ordered the wrong matrix, it's all green dot, so i cannot see the red dot, so ... i would think of buying this one :
http://www.sparkfun.com/products/681, is it okay for this game?
do i need to buy a common cathode or common anode?
thanks brad!
marC:)
by brad » Fri May 11, 2012 12:55 pm
Could you post a photo of the underside of your matrix?
nodoubtman
by nodoubtman » Fri May 11, 2012 1:55 pm
brad wrote:Could you post a photo of the underside of your matrix?
here is it :
thanks!
marC:)
nodoubtman
by nodoubtman » Fri May 11, 2012 2:11 pm
by bitfogav » Sat May 12, 2012 2:54 am
Just to note that those sparkfun matrix's are Common Cathode. you need Common Anode!.
Description: LED Matrix with dual-color LEDs. This small matrix has both bright-red and bright-green LEDs built into one common cathode housing.
by brad » Sun May 13, 2012 10:09 am
I've never seen those in the common cathode variety!
