wireless for two tilt switches
Post by MrDEB » Tue Feb 14, 2012 10:19 am
I should probably use a PIC at both ends but want to keep cost and size down as well as run on one or two coin cell batteries.
PLAN - using a 7555 connected as per attached picture, the transmitter transmits a frequency to receiver connected to a PIC that deciphers a sample and decides which tilt switch is closed.
A sample is say 1ms.
Hopefully this is doable?
link for rf link http://iteadstudio.com/store/index.php? ... ucts_id=31
open for any suggestions
plan to bread board to try out my theory.
555 tx.png (21.16 KiB) Viewed 7819 times
Re: wireless for two tilt switches
Post by brad » Mon Feb 20, 2012 7:54 pm
Very clever idea!
What type of transmitter are you using?
Post by MrDEB » Wed Feb 22, 2012 9:13 am
Hopefully this kit http://iteadstudio.com/store/index.php? ... ucts_id=27
Basically same that Sparkfun was selling.
I was informed that using a 555 as pictured would be iffy. Might not be reliable and will drop bits?
It was suggested over at Electrotec http://www.electro-tech-online.com/micr ... ation.html to use a 10F200 pic on the TX end.
The 7555 sounds less complicated IMO. Finishing up my soldering iron project and hopefully get back to this wireless project.
PS I found (Burt over at DIY and ELECTROTECH has the board I made of the Hako and found that I grounded the tab on the triac (dumb me).
If he gets it working GREAT he then has a Hako clone.
Post by brad » Wed Feb 29, 2012 6:18 pm
I don't see why the 555 would be unreliable. It should be very cheap so it would be worth trying it out.
