Tutorial 7 - All the info you need is right here!
rd1196
Re: Tutorial 7 - All the info you need is right here!
Post by rd1196 » Thu Aug 11, 2011 7:13 am
Hey brad the other day I tried to change the track data from the great race but when I saved it all the code turned into black and when I tried to make it a hex file (quickbuild) It said that there was no asm file
Post by brad » Thu Aug 11, 2011 9:52 pm
That is really strange.
Can you post the modified code here in the forum, i'll have a look at it.
nodoubtman
Post by nodoubtman » Fri May 11, 2012 12:09 am
brad wrote:Yep, they will do the trick. You will find different variations in the part number but as long as it has 74373 written in there, it will be fine.
Hi Brad! :)
I would like to write my name on this 8x8 matrix?
how can i do that?
Thanks!
marC:)
Post by brad » Fri May 11, 2012 8:14 am
Have a look at the great race code. In there is the track data (contained within the retlw statements) you can see the track drawn in the retlw statements with the binary 1's and 0's. To write your name, just modify the 1's and 0's.
You can then modify the code a bit to get rid of the game part and it will now just scroll your name instead.
nodoubtman
Post by nodoubtman » Fri May 11, 2012 11:53 am
brad wrote:Have a look at the great race code. In there is the track data (contained within the retlw statements) you can see the track drawn in the retlw statements with the binary 1's and 0's. To write your name, just modify the 1's and 0's.
ok! :) brad, thanks.. i will try to modify slighly the code, but i don't garanteed anithing! :)
ehhe
Cya!
Post by brad » Fri May 11, 2012 12:17 pm
Let me know how you go!
nodoubtman
Post by nodoubtman » Sat May 12, 2012 8:22 am
brad wrote:Let me know how you go!
santa scrabble is the same schematic as the great race??
thanks!
marC:)
nodoubtman
Post by nodoubtman » Sat May 12, 2012 12:27 pm
thanks!
marC:)
Brad i give up for now, it's too difficult thanks for helping!
marC:)
Post by brad » Sun May 13, 2012 10:06 am
No Problem - start small and then work your way up. That's how I did it!
nodoubtman
Post by nodoubtman » Wed May 16, 2012 5:01 am
brad wrote:No Problem - start small and then work your way up. That's how I did it!
BUT? Brad, santa scrabble is the same schematic as the great race??
thanks!
CYa!
Post by bitfogav » Wed May 16, 2012 6:33 am
marC if your still having problems with coding the Assembly code then try this?
The Scroller.asm
(15.51 KiB) Downloaded 337 times
It should scroll 1,2,3,4,5,6,7,8,9 Ive commented the section of code that you need to change if you want the matrix to say something else?
Gavin
nodoubtman
Post by nodoubtman » Thu May 17, 2012 12:42 am
bitfogav wrote:marC if your still having problems with coding the Assembly code then try this?
The Scroller.asm
Gavin
thank you!
marC:)
nodoubtman
Post by nodoubtman » Thu May 17, 2012 3:44 am
The Scroller.asm
Gavin
Is it possible to make it scroll bicolor ?
thanks!
marC:)
Post by bitfogav » Thu May 17, 2012 4:09 am
nodoubtman wrote:Is it possible to make it scroll bicolor ?
thanks!
marC:)
The Great Race and Santa’s Scramble schematic was only designed to use one colour. if you want a scrolling Matrix that uses bicolour then you might have to look at making a circuit like the 8x8 Game System.
nodoubtman
Post by nodoubtman » Thu May 17, 2012 4:17 am
thanks!
marC:)
ok, so the santa's scramble is using the same schematic right?
thanks!
marC:)
