by Chuckt » Sat Nov 07, 2015 10:52 pm
How the 741 op amp works
Op amps are used as amplifiers, filters, integrators, differentiators, and many other circuits.[2] Op amps are all around you: your computer's power supply uses op amps for regulation. Your cell phone uses op amps for filtering and amplifying audio signals, camera signals, and the broadcast cell signal.
http://www.righto.com/2015/10/inside-ub ... cuits.html
This is a good write up with explanations.
by brad » Thu Nov 12, 2015 6:59 pm
That is extremely cool!
It's not just showing the circuit diagram but actually labelling each component of that diagram on the silicon itself!
