I should have said that you need to send all 0's to the Green Anodes rather than all 1's to the Green Cathodes. You are 100% correct in saying that you can't send all 1's to the green cathodes at the same time
That's ok. I apologize for asking you to go back five years to talk about one of your early designs (lol).brad wrote:My Apologies Mike - I need to look at my own schematic properly next time!
Good, then we agree. The way you wired the 7442, you're only selecting "1 of 8" outputs instead of "1 of 9" outputs and so one green row is always left enabled when you enable the red row (and I hope you realize why this isn't desirable).You are 100% correct in saying that you can't send all 1's to the green cathodes at the same time
Well, that really doesn't work either, does it? Basically, there's no way to light a red LED and "send all 0's to the Green Anodes" at the same time. But, let's walk through it, just to be sure...I should have said that you need to send all 0's to the Green Anodes rather than all 1's to the Green Cathodes.
I'm baffled too, Brad. You mentioned on your projects web page that this was your first LED project and since it was from such a long time ago I wondered if you had maybe discovered and fixed the problem early on and simply forgotten to post an updated schematic and program before moving on to bigger and better things. Anyway, the problem didn't affect me because I had to come up with a different design. For one thing, I didn't have a 7442 IC, but more importantly, the 7442 wouldn't have worked because the sample Lumex display I had was the opposite type. Fortunately, the single chip design I came up with will support either "common anode row" or "common cathode row" display types.brad wrote:This is an interesting problem - Now that I have had a good look at the schematic I am a little confused as to how mine worked in the first place.
Yes Sir, that should work...The easiest fix would to leave the circuit as is but slightly modify the code so that when you want to draw the car on the screen, you make sure that the same row of green cathodes is enabled. This way, you won't get ghosting and will have an orange car.
