World smallest Time-of-Flight ranging and gesture detection
Post by Chuckt » Thu Nov 24, 2016 3:13 pm
World smallest Time-of-Flight ranging and gesture detection sensor
The VL53L0X from ST Microelectronics is a time-of-flight ranging system integrated into a compact module. This board is a carrier for the VL53L0X, so we recommend careful reading of the VL53L0X datasheet (1MB pdf) before using this product.
The VL53L0 uses ST’s FlightSense technology to precisely measure how long it takes for emitted pulses of infrared laser light to reach the nearest object and be reflected back to a detector, so it can be considered a tiny, self-contained lidar system. This time-of-flight (TOF) measurement enables it to accurately determine the absolute distance to a target without the object’s reflectance greatly influencing the measurement. The sensor can report distances of up to 2 m (6.6 ft) with 1 mm resolution, but its effective range and accuracy (noise) depend heavily on ambient conditions and target characteristics like reflectance and size, as well as the sensor configuration. (The sensor’s accuracy is specified to range from ±3% at best to over ±10% in less optimal conditions.)
http://www.st.com/content/ccc/resource/ ... 279086.pdf
Several places have boards made for this sensor and there is also a Github page here:
https://github.com/pololu/vl53l0x-arduino
Products:
https://www.pololu.com/product/2490
http://www.mouser.com/ds/2/389/53l0-satel-i1-953721.pdf
And interesting things can be done if you use it with a "3 axis gyroscope with 3 axis accelerometer".
http://www.electronics-lab.com/using-vl ... re-height/
Re: World smallest Time-of-Flight ranging and gesture detect
Post by brad » Sat Nov 26, 2016 8:28 pm
Correct me if i'm wrong, but could this be used in place of an ultrasonic transceiver?
