How to Arduino Kuman 37 Sensor Module The Starter Kit Robot
Post by Chuckt » Sun Sep 18, 2016 4:22 am
I could have put this in the Arduino forum but it works with Pic and Avr as well as other microcontrollers:
Professional 37-in-1 Sensor Module Kit for ARDUINO compatible
Complete Update and common models for arduino UNO NANO R3 Mega 2560 starter kit
compatible for raspberry pi RPi 3 2 Model B A A+ B+ sensor kits
Standard interface can be controlled directly by microcontroller ( 8051, AVR, PIC, DSP, ARM, ARM, MSP430, TTL logic)
Detailed tutorials including project introduction and source code CAN BE PROVIDED FOR FREE, contact us BY Email to get documents.
Update version than 37 sensors modules: add 100 X Resistors (10 each / 10, 100, 200, 330, 1K, 2K, 5K, 10K, 100K, 1m ohm) and one tutorilas CD at free
Packing list:
1. Analogy-Hall sensor Module×1
2. Magic-ring Module×1
3. Rotate-encode Module×1
4. Light break sensor Module×1
5. Finger-Pulse sensor Module×1
6. Magnetic spring Module×1
7. Obstacle avoidance sensor Module×1
8. Tracking sensor Module×1
9. Microphone sensor Module×1
10. Laser-transmit Module×1
11. Relay Module×1
12. 18b20 temperature sensor Module×1
13. Digital-Temperature sensor Module×1
14. Linear-Hall Sensor Module×1
15. Flame sensor Module×1
16. High-sensitive voice sensor Module×1
17. humiture sensor Module×1
18. Joystick PS2 Module×1
19. Infrared-receive sensor Module×1
20. Passive Buzzer Module×1
21. common-cathode RED&GREEN LED Module×1
22. Knock sensor module×1
23. Shock-switch sensor Module×1
24. Photo resistor sensor Module×1
25. Push button Module×1
26. tilt-switch Module×1
27. RGB LED Module×1
28. infrared-transmit Module×1
29. RGB LED Module (SMD)×1
30. hydrargyrum-switch sensor Module×1
31. two-color commoncathode LED Module×1
32. Active buzzer Module×1
33. Analog-temperature sensor Module×1
34. Colorful Auto-flash Module×1
35. Magnet-ring sensor Module×1
36. Hall sensor Module×1
37. touch sensor Module×1
https://www.amazon.com/Arduino-Kuman-Pr ... rd+Edition
I'm not sure how they can do all of this for $32.99 but...
Amazon lists other kits and other kits will come up on the bottom of the page that you can explore...
Re: How to Arduino Kuman 37 Sensor Module The Starter Kit Ro
Post by brad » Sun Sep 25, 2016 9:06 pm
I was selling these in my store! you can actually get them direct from China for less than $20.
Post by bitfogav » Mon Sep 26, 2016 3:19 am
What's the web address for your store Brad?
Post by brad » Wed Oct 05, 2016 7:45 pm
well it was www.bradselectronicsshop.com.au
But unfortunately people didn't seem to want to buy anything from there (after a few months I had sold maybe a dozen items) So I shut it down :)
I am now offloading bits and pieces on ebay. I guess it's hard to complete these days!
Post by bitfogav » Thu Oct 06, 2016 3:31 am
brad wrote:well it was http://www.bradselectronicsshop.com.au
I thought it was that web address, I was just a little confused when I visited the site and it said it would open early 2016, I thought the website address was incorrect.
Sorry to hear that you had to close it down, ebay seems the way to go though!.
Post by brad » Sat Oct 08, 2016 6:52 am
That's okay, I guess I now know how much work is involved in setting up even a small store :)
