Gameduino 2
Gameduino 2
http://www.kickstarter.com/projects/208 ... s-personal
Just watch the graphics. They speak for themselves.
Re: Gameduino 2
I figured out it is using the EVE (Embedded Video Engine) chip from FTDI that I may have talked about here before.
http://www.youtube.com/watch?v=xOJ0br7l ... r_embedded
Re: Gameduino 2
It do indeed use a EVE chip (FT800) looking at the design, I have been working with a dev board that contains the FT800 and interfacing it with Firewing/Swordfish.. It is a powerful chip the FT800..
Re: Gameduino 2
Very nice looking game system there.
I have to say that I am quite in awe over this sort of thing - I make simple LED games on an 8x8 matrix and I am sometimes wracking my brain to try and get the simplest thing to work. Then you look at a project like this and it just boggles my brain as to how they do it!
bitfogav - you've got me intrigued as to your new project
Re: Gameduino 2
Well check out this Eve TFT Disaply it contains a FT800 chip on the back of a TFT display, you can then control the TFT display via the FT800 and via SPI interface.brad wrote:bitfogav - you've got me intrigued as to your new project
Also check out this Visual TFT this is another tool which allows you to use a Visual Basic IDE style GUI which makes it so simple to draw shapes etc onto a TFT screen via a FT800. the down side is that its not free software..
The easy bit is controlling the FT800 with Firewing/Swordfish, the hard bit would be putting together the interface GUI.
Re: Gameduino 2
David Barker has beat me to it, he has ported over the Gameduino2 code to Firewing.
check following link Firewing FT800
Re: Gameduino 2
David Barker is one very clever man I must say. I like what he did with the Gameduino logo
Re: Gameduino 2
Yes indeed he is very clever!. I like the widgets code, 7 seg display and some visual gauges, that will be very handy for making a display with several sensor readings!.
Re: Gameduino 2
Looks perfect for a motorbike display!
- newbie
- Joined: Mon Mar 17, 2014 3:27 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Gameduino 2
...or if you would like to go all retro with your display
Re: Gameduino 2
Very nice David - I would have sworn that video was of actual nixie tubes!
This would make a great retro clock
Users browsing this forum: No registered users and 14 guests
