help with programing
- Joined: Mon Aug 30, 2010 8:05 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
witch are the pic's outputs I have connect to the pickit2?
Re: help with programing
The image is a little small but it should do the trick
thanks a lot
hey brad, i really don't have a clue about how to program the pic you think you can tell me where to find a good tutorial or tell me witch part of the source code should i copy to my pic
Certainly!rd1196 wrote:hey brad, i really don't have a clue about how to program the pic you think you can tell me where to find a good tutorial or tell me witch part of the source code should i copy to my pic
http://www.bradsprojects.com/electronic ... rials.html
is there a way you can upload the exact code so i can copy it?
All the info you should need is on Brads tutorials
heres the Assembly code for the flashing LED. Your still need to download MPLAB (compiler) to turn the code into HEX file so you can then use your pickit2 to load the HEX file onto your microchip.
MPLAB IDE v8.70 can be downloaded from the bottom of this page
http://www.microchip.com/stellent/idcpl ... t=SW007002
Heres the asm file (ZIP) from Brads flashing LED tutorial2:
I downloaded the MPLAB and I opened the source code on it but how do I turn it into a hex file?
Have a read through tutorial 1 and 2 it has all the information in a handy step by step format
Thanks that tutorial helped me understand a lot of things but I still don't quite know what to do after I opened the source code by MPLAB IDLE, I mean how do I copy it to the pickit2
sorry I forgot to read tutorial 2 but now i know how to turn it into a hex file. I have a problem connecting the chip to the pickit2 it says device no device detected even if my pic is connected to the program
Could you please take a screenshot for us just to see exactly what is happening?
hello brad i wanted to ask you if you can program the microchip while its in the circuit connected to everything. if so how do you do it
You certainly can!
you just need to have the pickit2 connected as the image shows above. It does not matter that the microcontroller is still in the circuit
hello brad
I dont know why when i click import hex file it says device error, hex file not loaded
