Hi everyone.
I have been working with David Barker to put together a Color TFT library, but I must say that David has done alot of the work..
I have a Demo Video which is a port from the Arduino TFT Demo.
The Demo is running on a Firewing board which is clocking at 80Mhz..
This is an early test video when I was trying to interface the TFT with Firewing Board..
Firewing Color TFT Library
Re: Firewing Color TFT Library
Nice one bitfogav! How many FPS can you get from this when running at 80Mhz?
How many colors can you get from it?
Do you have the code for your demo video?
Im sorry I can't really give you an FPS Brad, it depends on the render time it takes within the Graphic subroutines and what you are sending out to the display.. But it is pretty quick!.brad wrote:How many FPS can you get from this when running at 80Mhz?
The shield we have used is one from IteadStudio 2.4 TFT Display. It has just over 262K of colors.brad wrote:How many colors can you get from it?
We have a routine abit like - "SetPenColor(255, 255, 255)" within each parameter you can enter a value between 0-255, which represents (RED, GREEN, BLUE).
I have some example code below, but all the examples including the code will be released soon.brad wrote:Do you have the code for your demo video?
' drwa header and footer
Tft.Clear()
Tft.SetBrushColor(255, 0, 0)
Tft.FillRect(0, 0, 319, 13)
Tft.SetBrushColor(64, 64, 64)
Tft.FillRect(0, 226, 319, 239)
Tft.SetFont(Fixed)
Tft.Brush.Style = BrushStyle.IsClear
Tft.Graphic.Align = TextAlign.Center
Tft.SetPenColor(255, 255, 255)
Tft.WriteStr(160,3,"* Firewing Color Tft Display Library *")
Tft.SetPenColor(255,255,0)
Tft.WriteStr(160,229,"<http://www.firewing.info>")
' draw border
Tft.SetPenColor(255,255,255)
Tft.SetBrushColor(0, 0, 255)
Tft.Rect(0, 14, 319, 225)
' draw crosshairs
Tft.SetPenColor(0, 0, 255)
Tft.setBrushColor(0, 0, 0)
Tft.Line(159, 15, 159, 224)
Tft.Line(1, 119, 318, 119)
for i as ushort = 9 to 310 step 10
Tft.Line(i, 117, i, 121)
next
for i as ushort = 19 to 220 step 10
Tft.Line(157, i, 161, i)
next
' Draw sin-, cos- and tan-lines
Tft.SetPenColor(0,255,255)
Tft.WriteAt(5,15,"Sin")
for i as ushort = 1 to 317
Tft.SetPixel(i,119 + (sin(((i*1.13)*3.14)/180)*95))
next
Tft.SetPenColor(255,0,0)
Tft.WriteAt(5,27,"Cos")
Tft.SetPixel(i,119+(cos(((i*1.13)*3.14)/180)*95))
next
Tft.WriteAt(5,39,"Tan")
Tft.SetPixel(i,119+(tan(((i*1.13)*3.14)/180)))
next
I have had in my mind to write a module for SF Basic for the 32x32 LED matrix. All this info here will come in handy fo that! (If I ever get around to doing it.) So far I have been able to draw individual pixels, box outlines, filled boxes and I had a bit of a hard time getting lines to be drawn.
One day I'll get there.
By the way, $19 for a TFT touch screen! Bargain!
Yes of course I still got my 32x32 Led matrix to get around too as well, Look at the GLCD library in Swordfish? im sure that will helpbrad wrote:I have had in my mind to write a module for SF Basic for the 32x32 LED matrix. All this info here will come in handy fo that! (If I ever get around to doing it.) So far I have been able to draw individual pixels, box outlines, filled boxes and I had a bit of a hard time getting lines to be drawn.
Ive just posted on the Firewing Wiki..
Introduction into the Firewing Color TFT Library
And a list of samples for the Color TFT Library
Sample Codes
Sample Codes
Thanks Gav, will have a good read and see what I can borrow to use with my 32x32 matrix.
One day I'll get to those TFT displays!
