Controlling a RGB with PWM
Posted: Sun Sep 08, 2013 11:18 pm
Simple programme to control a single RGB led using Swordfish.
You may need to download the random gen module and include it into your user library folder.
Device = 18F4550
Clock = 48
Config PLLDIV = 5,
CPUDIV = OSC1_PLL2,
USBDIV = 2,
FOSC = HSPLL_HS
Include "RandGen.bas"
Dim TMR2IE As PIE1.1, // TMR2 interrupt enable
TMR2IF As PIR1.1, // TMR2 overflow flag
TMR2ON As T2CON.2, // Enables TMR2 to begin incrementing
Signal_Pin As PORTB.0 // Signal output to frequency meter
Dim Red_Pin As PORTC.0,
Green_Pin As PORTC.1,
Blue_Pin As PORTC.2,
Red_Duty As Byte,
Green_Duty As Byte,
Blue_Duty As Byte,
Red_DutyVal As Byte,
Green_DutyVal As Byte,
Blue_DutyVal As Byte,
RandomVal As Byte
Dim uS As Word,
mS As Word
Interrupt TMR2_Interrupt()
High(Signal_Pin)
Save(0) // Back up system variables
If TMR2IF = 1 Then // Check if the interrupt was from TMR2
TMR2IF = 0 // Clear the TMR2 interrupt flag
uS = uS + 50
If uS >= 1000 Then
uS = uS - 1000
Inc(mS)
Inc(Red_DutyVal)
Inc(Green_DutyVal)
Inc(Blue_DutyVal)
If Red_DutyVal > Red_Duty Or Red_Duty = 0 Then
Red_Pin = 0
Else
Red_Pin = 1
If Green_DutyVal > Green_Duty Or Green_Duty = 0 Then
Green_Pin = 0
Else
Green_Pin = 1
If Blue_DutyVal > Blue_Duty Or Blue_Duty = 0 Then
Blue_Pin = 0
Else
Blue_Pin = 1
Restore // Restore system variables
Low(Signal_Pin)
End Interrupt
Private Sub TMR2_Initialize()
TMR2ON = 0 // Disable TMR2
TMR2IE = 0 // Turn off TMR2 interrupts
PR2 = 149 // TMR2 Period register PR2
T2CON = %00000001 // T2CON 0:1 = Prescale
// 00 = Prescale is 1:1
// 01 = Prescale is 1:4
// 1x = Prescale is 1:16
// 3:6 = Postscale
// 0000 = 1:1 postscale
// 0001 = 1:2 postscale
// 0010 = 1:3 postscale...
// 1111 = 1:16 postscale
TMR2 = 0 // Reset TMR2 Value
TMR2IE = 1 // Enable TMR2 interrupts
TMR2ON = 1 // Enable TMR2 to increment
Enable(TMR2_Interrupt)
// Start Of Program...
Low(Red_Pin)
Low(Green_Pin)
Low(Blue_Pin)
Red_Duty = 0
Green_Duty = 0
Blue_Duty = 0
Red_DutyVal = 0
Green_DutyVal = 0
Blue_DutyVal = 0
uS = 0
mS = 0
RandGen.Initialize(128) // Initialize the Random Number generator
TMR2_Initialize // Setup and enable TMR2
While True // Create an infinite loop
RandomVal = RandGen.Rand // Grab a random number from 0 to 255
Select RandomVal // Find out what colour to increase/decrease
Case 0 To 42
While Red_Duty < 255
mS = 0
Repeat
Until mS = 19
Inc(Red_Duty)
Wend
Case 43 To 84
While Red_Duty > 0
mS = 0
Repeat
Until mS = 19
Dec(Red_Duty)
Wend
Case 84 To 127
While Green_Duty < 255
mS = 0
Repeat
Until mS = 19
Inc(Green_Duty)
Wend
Case 128 To 170
While Green_Duty > 0
mS = 0
Repeat
Until mS = 19
Dec(Green_Duty)
Wend
Case 170 To 212
While Blue_Duty < 255
mS = 0
Repeat
Until mS = 19
Inc(Blue_Duty)
Wend
Case 212 To 255
While Blue_Duty > 0
mS = 0
Repeat
Until mS = 19
Dec(Blue_Duty)
Wend
End Select
Wend
