Polymorph - make your own plastics
I was watching a video on Polymorph. You can boil water, place polymorph in the water and then once it melts, you can mold it or place it in your own molds and then it gets hard until you melt it again. I have no idea if the product is safe or is lead free.
Re: Polymorph - make your own plastics
That would be fantastic for super pixel bros!
Do you know where you can buy it?
Yes.
http://www.sparkfun.com/products/10951
I learned about it from this video at 1:34:
It is available at a little more at Robotshop:
http://www.robotshop.com/dagu-polymorph ... mpaign=jos
From what I read, this is non-toxic but read the labels and make sure. I'm sure it isn't healthy to ingest.
I'm sure google is our friend at finding it under other names.
The alternate is Sugru and I think Hackaday might have had a formula for this.
https://www.adafruit.com/index.php?main ... word=sugru
http://www.sparkfun.com/search/results? ... t=products
Hackaday did show some other chemical for making cases but I can't find it. I haven't been able to find it but I think it is more professional.
How to make your own resin:
http://blog.rhysgoodwin.com/fabrication ... enclosure/
This isn't it but I'm trying to find it. This is an eye irritant.
Using polycarbonate filament with a RepRap
http://hackaday.com/2011/09/30/using-po ... -a-reprap/
It was something about a case and spot putty and using a dremel but it was on Hackaday and not Benheck.
http://forums.benheck.com/viewtopic.php?f=3&t=23372
It might have been Bondo or ABS cement:
Now I'm going to search for Bondo.
Case Mod with Bondo and Fillers:
http://www.overclock.net/case-mods-gene ... ers-q.html
This "The Power of Bondo" has some good tutorials on using Bondo to make a case:
The Power of Bondo:
http://hacknmod.com/hack/the-power-of-b ... -tutorial/
When I find a better demonstration on bondo, I will try to post. I saw a really good one on Hackaday but I can't find it. I'm emailing them.
http://hackaday.com/2009/11/08/gamecube-to-go/Starting with the case from a Kidz Delight Datamax game, he used Bondo ABS cement and plastic bumper filler to alter the case but still provide a professional look.
The Power of Bondo:
I wonder how much you get in the box. I see that it says 1000 grams, but if this stuff is really heavy then that means you don't get a whole heap. But then again if it is pretty light, then one box should go a long way. I like that it is reuseable
I emailed sparkfun about the size of the box. They may try to get back to me sometime on Monday or whenever they get around to it.
Excellent!
Robotshop sells it and first answered my question:
Waiting on Sparkfun.....
Since this stuff melts, I wonder how much you don't get back from repeated meltings. Clothes shrink in the dryer. At what proportion are properties that don't re-solidify are lost in the water? I wonder if there is a home made recipe for this stuff...The bin measures roughly 3x4x6" and the bag inside is about 3/4 full of the pellets. Given that there are many voids between the pellets, we can guess that the space taken up by the melted plastic would be ~1/2 the volume.
Plastics has a number for recycling. I'm wondering now how they recycle it. Is it possible that certain plastics with certain numbers can be melted like polymorph and that we're throwing away a valuable commodity through recycling?
Sparkfun answered:
The box is about 8" x 5.5" x 3.5"
Thanks for the info Chuck!
