Post here to discuss The Great Race.
nodoubtman
Post
by nodoubtman » Tue Jul 17, 2012 11:12 pm
brad wrote:Have a look through the great race code and modify the track data to suit your text. (The great race just scrolls a table of data - so putting text in there will scroll the text)
i don't know how to modify it..sorry!
thank you!
marC:)
Post
by brad » Wed Jul 18, 2012 9:43 pm
First see if you can get the game working, then we can help you modify it to show your text.
nodoubtman
Post
by nodoubtman » Thu Jul 26, 2012 11:25 pm
here we go :
http://www.youtube.com/watch?v=4a7sWYNU ... e=youtu.be
i would like to write happy birthday message or others message on the matrix?
can you help me do that ?
thanks a lot!
marC:)
nodoubtman
Post
by nodoubtman » Fri Jul 27, 2012 12:12 am
i have figured it out by myself, it works!
thank you brad and bitfogav!!!
you have been a great help!
thanks a lot to all!
happy day!
marC:)
Post
by brad » Sun Jul 29, 2012 1:28 pm
Great to hear that it is working for you!
nodoubtman
Post
by nodoubtman » Thu Aug 09, 2012 8:08 am
i tried for the great race with red dot, and button, and it doesn't work, ... can you draw me same thing as bigof would be reallly really appreciate, by the way, i have soldered scrolling numbers from bigof, and i made my own personal message scrolling it is nice
thanks a bunch!
good evening!
marC:)
Post
by brad » Fri Aug 10, 2012 1:16 pm
nodoubtman
Post
by nodoubtman » Thu Aug 16, 2012 5:01 am
i am talking about this kind of drawing :
http://img39.imageshack.us/img39/2416/m ... ctions.jpg
thanks!
marC:)
Post
by brad » Sat Aug 18, 2012 9:26 am
The picture you posted lines up exactly with the schematic. Put those two pictures next to each other on your computer screen and compare them. Have a look at where each connection goes and you will see they are the same.
The only extra thing you need to add is the one extra wire on pin 2 of the microcontroller to the red cathodes on the led matrix (which should be the red dot in the bottom right corner on bitfogavs drawing.)
rd1196
Post
by rd1196 » Mon May 06, 2013 6:46 am
I just finished a prototype of the great race for a school project but for some reason column 5 and 7 switched places so all the data that is supposed to be on column 7 is on column 5 and vice versa. This project is due soon can you please point out all possible causes for this to happen?
- Moderator
Post
by bitfogav » Mon May 06, 2013 8:05 pm
What if you swap the connections over from column 5 to 7?
rd1196
Post
by rd1196 » Tue May 07, 2013 12:38 am
I guess i can try that, could there be any other source for this problem?
Post
by brad » Tue May 07, 2013 9:54 pm
Unfortunately it's very hard for us to know the fault without seeing the physical circuit. But it happens to the best of us whereby we get connections around the wrong way. Give that a try in the first instance and if it's still no good we shall see where we can get to from there.
rd1196
Post
by rd1196 » Wed May 08, 2013 12:30 am
I guess ill have to make a more thorough check because from a quick look i took that did not seem to be the problem
Thanks again
Post
by brad » Sat May 11, 2013 8:33 pm
Okay, keep us posted!
1266:
Users browsing this forum: No registered users and 13 guests
