BJT Biasing App for iOS
Post by brad » Fri Jul 20, 2012 7:48 am
Hi guys, I made an app for my students in order to help them understand different BJT circuits. Basically the app allows you to select from three biasing circuits:
:arrow: Fixed Bias
:arrow: Fixed Bias With Emitter Resistor
:arrow: Voltage Divider Bias
You can then vary different values in the circuit by moving sliders up and down. You can vary:
:arrow: Resistor values
:arrow: Power Supply Voltage
:arrow: Transistor Gain
The app will then plot in real time the Q-point and calculate Ib, Ic, Vce, Icsat, Vceco. It also calculates Vb and Ve for the voltage divider circuit.
You can check out the page on brads projects here:
http://www.bradsprojects.com/electronic ... asing.html
The app should be approved by apple within the next week or so.
