Hi guys, for awhile now one of my set of led's in my vehicle rear lamps have stopped working, so I thought I would instigate the problem and share what I found here, So I stripped out the pcb board from the rear lamp which included the strip of led's and tested the power and ground supply to the pcb (13volts) all good.
So looking closer at the pcb I found a simple circuit which included a regulator and a strip of led's in series, I tested the power output from the pcb regulator to the strip of led's all good and the ground was good, so I knew the regulator must be fine, I made up a simple led tester and tested each led individually in circuit and bingo! found one of the led not working, it was a dry solder joint, resoldered the led pin and repowered the pcb, all working its abit hard to see the led's on the pictures but they go just below the top red lamp.
Lamp led's not working:
pcb board:
lamp working:
Bitfogavs Rear Vehicle Light Repair
Re: Bitfogavs Rear Vehicle Light Repair
Nice work bitfogav, and thanks for sharing!
It's always great to track down and fix a fault - rather than pay (most probably) multiple hundreds to get someone else to do it...
Yes very true Brad or even buy a new unit (Lamp)?!
