Hi everyone,
I have been busy working on an instructable that shows you how to create my latest project - an eight LED RGB POV display that is capable of displaying text, graphics and animations. I have also come up with a couple of VB.NET applications which allow you to import your own graphics, the software will then convert the graphic into 3-bit colour and export the code for you to paste into swordfish basic. You just need to compile it and program to the microcontroller. No coding required!
The display can scroll a large image from top to bottom, or it can scroll a long image from right to left.
here is the instructable link:
http://www.instructables.com/id/The-One ... ith-conve/
Here is a photo of the display running in scroll left mode:
here is a photo of the display running in 'scroll down' mode (it is displaying eight vertical pixels of the image to the right)
And here is a photo showing what the display would look like if you had alot of LED's:
One Chip RGB POV Display instructable online!
Re: One Chip RGB POV Display instructable online!
You've got my vote on instructables Brad
Thanks bitfogav!
If I win one of the 1st prizes, i'll be going on a sparkfun shopping spree!
Is there a FREE download of VB?
SF code for this project? I downloaded the files from INSTRUCTABLES but ?
Hopefully I can download all required code etc.
You can download VB.Net for free (It is called Visual Studio Express)
http://www.microsoft.com/express/Downlo ... sual-Basic
As for the code, I didn't post any code anywhere because the software generates the code for you depending on what picture you have converted. But here is some example code that will scroll through the super mario bros image:
// The One Chip Spinning POV Display - SCROLL UP CODE //
// By Brad Slattery 2011 //
// www.bradsprojects.com //
// Philippians 4v13; I can do all things through Christ who strengthens me. //
Device = 18F4680 // Tell the compiler what chip we are using
Clock = 8 // Tell the compiler what we will be setting the clock to (Mhz)
Config OSC = IRCIO67 // This tells the microcontroller to use the internal clock
Include "utils.bas"
// Arrays
const RedData(2592) as byte = ' I HAVE HAD TO LEAVE OUT THIS DATA BECAUSE THERE IS TOO MUCH TO FIT IN THE FORUM
const GreenData(2592) as byte = ' I HAVE HAD TO LEAVE OUT THIS DATA BECAUSE THERE IS TOO MUCH TO FIT IN THE FORUM
const BlueData(2592) as byte = ' I HAVE HAD TO LEAVE OUT THIS DATA BECAUSE THERE IS TOO MUCH TO FIT IN THE FORUM
// variable declaration
Dim ShiftRight As Word
Dim StartShiftRight as word
Dim Width As Word
dim StartWidth as word
Dim x As word
Dim ShiftLeft As Word
dim StartShiftLeft as word
Dim LineCounter As Word
Dim StartLineCounter as word
Dim RefreshCounter As Byte
dim StartRefreshCounter as byte
Dim DataOutRed As Byte
Dim DataOutGreen As Byte
Dim DataOutBlue As Byte
Dim DataOutRedNext As Byte
Dim DataOutGreenNext As Byte
Dim DataOutBlueNext As Byte
Dim OutputRed As Byte
Dim OutputGreen As Byte
Dim OutputBlue As Byte
dim AnimationHeight as word
Dim LedHeight as byte
dim DelayOn as word
dim DelayOff as word
dim AnimationSpeed as byte
// Sub Routines
Sub DisplayGraphics()
For x = (Width - StartWidth) To (Width - 1)
DataOutGreen = GreenData(x) << ShiftLeft
DataOutRed = RedData(x) << ShiftLeft
DataOutBlue = BlueData(x) << ShiftLeft
DataOutGreenNext = GreenData(x + startwidth) >> ShiftRight
DataOutRedNext = RedData(x + startwidth) >> ShiftRight
DataOutBlueNext = BlueData(x + startwidth) >> ShiftRight
OutputRed = DataOutRed Or DataOutRedNext
OutputBlue = DataOutBlue Or DataOutBlueNext
OutputGreen = DataOutGreen Or DataOutGreenNext
PORTD = OutputRed
PORTB = OutputBlue
PORTA = OutputGreen
PORTE.bits(0) = OutputGreen.bits(6)
PORTE.bits(1) = OutputGreen.bits(7)
DelayUS(DelayOn)
PORTA = 0
PORTB = 0
PORTD = 0
PORTE = 0
DelayUS(DelayOff)
Next
RefreshCounter = RefreshCounter + 1
If RefreshCounter = AnimationSpeed Then
LineCounter = LineCounter + 1
ShiftLeft = ShiftLeft + 1
ShiftRight = ShiftRight - 1
RefreshCounter = StartRefreshcounter
If ShiftLeft = LedHeight Then
width = width + startwidth
ShiftLeft = StartShiftLeft
ShiftRight = StartShiftRight
If LineCounter = (AnimationHeight - (ledheight - 1)) Then
LineCounter = StartLineCounter
WIDTH = STARTWIDTH
RefreshCounter = StartRefreshCounter
// Start Of Program
OSCCON = %01111111 // Sets the internal oscillator for 8Mhz
SetAllDigital // Make all Pins digital I/O's
TRISD = %00000000 // Make PORTD all outputs
TRISB = %00000000 // Make PORTB all outputs
TRISC = %00000000
TRISA = $00000000
TRISE = %00000100
PORTA = %00000000
PORTB = %00000000
PORTC = %00000000
PORTD = %00000000
PORTE = %00000000
StartLineCounter = 0
StartShiftLeft = 0
StartShiftRight = 8
LedHeight = 8
StartRefreshCounter = 0
StartWidth = 96
AnimationHeight = 216
DelayOn = 40
DelayOff = 15
AnimationSpeed = 2
shiftleft = Startshiftleft
shiftright = Startshiftright
WIDTH = StartWIDTH
// Main Loop
While True() // This creates an infinite loop
If PORTE.bits(2) = 0 Then
DisplayGraphics
Wend // Loop back to the while loop as long as we havent finished.
Users browsing this forum: No registered users and 12 guests
