Christmas Tree Project
Posted: Thu Dec 24, 2015 6:14 am
Well it's coming up to that time of year again!, here's a quick project I put together for some christmas decorations.
It's a 16 led christmas tree controlled by using 2x shift registers 74595's.
I know this isn't anything new because I've seen many kits around for this type of thing but I wanted to make my own, the PCB board was designed using Diptrace and I got the boards made by iTeadstudio,
apart from some leds, resistors and the 74595's there isn't much to the boards.
The boards are controlled using a Arduino board but I guess they will work with any chip processor, only 5 connections are needed to run the christmas tree (Power, Ground, data line, latch line and clock line).
If I had more time I would have probably included a pic and battery holder on the design, but I wanted the boards by christmas :) maybe next year!?...
Images of the christmas tree board
Example video of the christmas tree in many colours, running on one Arduino (clone) board:
// data pins setup...
const int clockPin = 5;             // connect to "C" on pcb
const int latchPin = 6;             // connect to "L" on pcb
const int dataPin = 7;              // connect to "D" on pcb
// the setup function runs once when you press reset or power the board...
void setup() {
  pinMode(latchPin, OUTPUT);        // set our digital pins to output.
  pinMode(clockPin, OUTPUT);        // "
  pinMode(dataPin, OUTPUT);         // "
  // read analog input pin 0, as pin is unconnected, this should give us a random
  // value for our random seed. see web arduino.cc/en/Reference/RandomSeed
  randomSeed(analogRead(0));
// the loop function runs over and over again forever...
// here we call each function one after the other.
void loop() {
  ledRandom();
  nightRider();
  allLedsOn();
// flash all leds On/Off...
void allLedsOn(){
  for (int j = 0; j < 8; j++) {
    //all leds on
    shiftOut(dataPin, clockPin, MSBFIRST, B11111111);             // we need to send 16bits to the tree
    shiftOut(dataPin, clockPin, MSBFIRST, B11111111);             // 2x 8bit shift registers
    digitalWrite(latchPin, HIGH);                                 // strobe latch pin to store data
    digitalWrite(latchPin, LOW);
    delay(500);                                                   // delay
    //all leds off
    shiftOut(dataPin, clockPin, MSBFIRST, B00000000);
    delay(500);
// night rider effect...
void nightRider(){
  int delayTime = 80;               // delay betweek each led on, change value to suit
    shiftOut(dataPin, clockPin, MSBFIRST, B00000001 << j);      // send first 8bits
    shiftOut(dataPin, clockPin, MSBFIRST, B00000000);           // send second 8bits
    delay(delayTime);
    delay(delayTime);
    shiftOut(dataPin, clockPin, MSBFIRST, B10000000 >> j);
    delay(delayTime);
    delay(delayTime);
// random flashing of all leds...
void ledRandom(){
  int randNumber = 0;                                     // a holder for our random num
  for (int j = 0; j < 100; j++) {                         // loop 100 times
    randNumber = random(255);                             // print a random number from 0 to 255
    shiftOut(dataPin, clockPin, MSBFIRST, randNumber);    // send first 8bits to tree
    shiftOut(dataPin, clockPin, MSBFIRST, randNumber);    // send second 8bits to tree
    delay(randNumber = random(50, 250));                  // delay between 50-250ms (random)
XmasTreeV1.zip
The Diptrace board file
(23.77 KiB) Downloaded 863 times
Re: Christmas Tree Project
Posted: Fri Dec 25, 2015 10:51 am
Well themed project Gav! This will certainly be making an appearance on my homepage :)
I was just thinking, if you do another version later on, maybe you could have six connections per board - the extra connection could be data out. That way you could have one 'master' tree which sends data through to all the other trees!
Posted: Sat Dec 26, 2015 9:55 pm
brad wrote:I was just thinking, if you do another version later on, maybe you could have six connections per board - the extra connection could be data out. That way you could have one 'master' tree which sends data through to all the other trees!
Yes when I received the boards and built them, I thought about that and wished I added that extra connection. Good idea, thanks Brad.
