im going to buy some chips like the 16f648a so i can leave them in projects without having to reuse them. when i go on microchip direct and search for it, it seems that there is a large range. just wondering what i should get, thanx
http://www.microchipdirect.com/ProductS ... PIC16F648A
microchip direct
Re: microchip direct
The 16f648a will do you for most of your projects, you want the Package type PDIP.
I would keep with the 16f648a microchip.. And as you learn more about microchips then you could move up to the 18F series and programme using Swordfish.
Yep, just as bitfogav said, most of them will be surface mount - your want the pdip package which has the legs that go through the PCB or can go into a breadboard.
- Fluroblue
- decided to stick around...
- Location: (the Shire) Sydney, Australia [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
thanx i was just a bit confused with the extra set of letters on the end
