Is this 1/64th tip good for Surface Mount Soldering?
Posted: Mon May 10, 2010 9:21 am
I thought this soldering iron tip is good enough to work with Surface Mount Solering but the tutorials say I should use an iron with 50 watts and the iron it is used for is 30 Watt. I'm not sure other than they may want the solder to stay hot before it forms?
http://www.sparkfun.com/commerce/produc ... ts_id=9538
If I can get away with it, it would be a cheap solution to SMS (with pitfalls).
After studying it some more, they say that a screwdriver or chizel size chip holds more solder and they are using a 1/32 inch tip.
