24 db gain Wifi Antennas from I-Com
Post by Chuckt » Fri Dec 21, 2012 2:04 pm
I was reading a blog about a lady who built and lives in a small 130 square foot house:
http://shine.yahoo.com/photos/tiny-hous ... slideshow/
I actually went to her blog and found out she doesn't have internet:
http://littleyellowdoor.wordpress.com/
And I found that you can actually buy these small houses as plans or kits:
http://www.tumbleweedhouses.com/pages/houses
So how do you power up your wifi to get connected and share someone's internet? There is a provider of high powered wifi antennas:
http://www.l-com.com/productcenter.aspx?id=2005
You can get a 24 db gain WiFi dish antenna and they come with an RG8 cable with rp-sma termination which work with half watt USB adapters. They cause a lot of RF so I'm not sure how much they would heat up something with water but they should probably be mounted high up on a wall or a roof if you want to share someone's wifi signal. This will also increase your chance of having your computer hacked unless you are in a rural location.
Then you can get a second antenna and aim them in different directions but you have to spend some time aiming the antennas.
Someone is going to ask what db gain is and I believe that 24 dB is the maximum allowed in the United States by the Federal Communications Commission:
dMystifying the dB
http://www.moonblinkwifi.com/dmystifying_the_db.cfm
Re: 24 db gain Wifi Antennas from I-Com
Post by brad » Sat Dec 22, 2012 8:29 pm
Such a cool house, although where would I set up my electronics workshop?
