Netduino - using Visual studio C#
Post by bitfogav » Tue Apr 12, 2011 8:24 am
Hey people.
Netduino is an open source electronics platform using the .NET Micro Framework.
Featuring a 32-bit microcontroller development environment.
All software is free inc Microsoft Visual C# Express 2010, everything you need can be found at the link below.
http://www.netduino.com/
Heres an example of code to flash a led:
using System;
using System.Threading;
using Microsoft.SPOT;
using Microsoft.SPOT.Hardware;
using SecretLabs.NETMF.Hardware;
using SecretLabs.NETMF.Hardware.Netduino;
namespace Netduino_Blinky
    public class Program
        public static void Main()
            // write your code here
            OutputPort led = new OutputPort(Pins.ONBOARD_LED, false);
            while (true)
                led.Write(true); // turn on the LED
                Thread.Sleep(1250); // sleep for 250ms
                led.Write(false); // turn off the LED
Re: Netduino - using Visual studio C#
Post by brad » Tue Apr 12, 2011 9:00 pm
That's pretty cool bitfogav, have you been experimenting with one yourself?
Post by bitfogav » Wed Apr 13, 2011 3:52 am
I have been experimenting as far as visual studios C# and with the syntax of Netduino.
Someone on the Netduino website has made an application emulator of the Netduino board, it is very basic though with just a button and led, so I have been experimenting with that..
My Netduino is in the post! ;) :D
Post by brad » Wed Apr 13, 2011 6:01 am
How much did it cost?
Post by bitfogav » Wed Apr 13, 2011 6:11 am
it was £25
At the time of priniting this 25.00 British pounds sterling = 38.66 Australian dollars
