http://www.latinospost.com/articles/240 ... deshow.htmHonda UK decided that 15 miles per hour - the top speed of many of the fastest riding lawn mowers - was just not fast enough. So Honda UK teamed up with their British Touring Car Championship-winning partner, Team Dynamics, to revamp the Honda HF2620 Lawn Tractor from the ground up. The result? A riding lawn mower, called the Mean Mower, which goes from zero to 60 in four seconds, and is capable of reaching a top speed of an estimated 130 miles per hour.
Honda's Mean Mower Goes from 0 to 60 In Under Four Seconds
Re: Honda's Mean Mower Goes from 0 to 60 In Under Four Secon
I wonder what the lawn would look like after the job is done
I think it cuts grass at 15 MPH which defeats the purpose of going fast. In some ways, it is more dangerous than a car because you aren't enclosed, you don't have airbags and ground surfaces are not stable at high speeds especially when soft or wet.
This topic is more entertainment than electronics so you may delete it when the need arises.
No need to delete, it's nice to see interesting things like this around these humble forums!
