Brads Electronic Projects Forum • EVE - Embedded Video Engine
Posted: Sun Mar 03, 2013 10:27 am
by Chuckt
Eve - Embedded Video Engine
Launched at Embedded World 2013, FTDI Chip has taken its first steps into another vital application sector, addressing the need for easy to design, advanced forms of human-machine interaction; with the technology release of EVE, Embedded Video Engine series and the initial chip offering the FT800.
The FT800 combines display, audio, and touch into a single chip, providing an optimized solution that reduces power, board area, BOM costs, and much more. EVE provides a high quality graphic solution, check out this new technology in action (3.3 minute video).
Targeted at QVGA and WQVGA resolution TFT displays with parallel RGB interface
Dithering hardware provides 24-bit (true colour) support on an 18-bit interface
256k internal object memory
Store up to 2000 objects in 8k byte display list
Inbuilt controller supports 4-wire resistive touch panels
PWM output for programmable display brightness
Anti-aliasing support improves display perception
Low-power - 35mA typical in active mode down, and 25uA in sleep mode
Widgets (innovation mechanisms) allow easy creation of complex objects (e.g analog clocks)
Integrated audio output - play beeps, tones or recorded audio
SPI or I2C interface to system microcontroller
Space saving 48LD QFN package
http://www.ftdichip.com/EVE.htm
Re: EVE - Embedded Video Engine
Posted: Sun Mar 03, 2013 1:35 pm
Very nice to see the Amiga Boing making an appearance!
I had no idea FTDI made this sort of stuff, very impressive!
