I have seen this before but it is quite interesting and entertaining.
Intel vs. AMD - What happens when you remove the fan?
- sdudley
Re: Intel vs. AMD - What happens when you remove the fan?
Interesting. My guess is that the AMD was not designed to run without a fan.
It's quite amazing how quickly they heat up!
What I've learned since posting this is they were old chips and they have fixed the problem.
They've made improvements in speed with the architecture rather than bumping up the clock speed. Now they solder the heatsink/fan on the CPU so there is no longer a danger of them falling off. They abandoned the netburst architecture and went back to the P3 CPU design which is more efficient at lower clock speeds and in 2001 Intel was the only company to have good thermal protection.
I do remember reading something about how the PIII chip was quite a good design. Much better than the P4
Users browsing this forum: No registered users and 16 guests
