DS100BR410 with 10 Gbps Repeaters Double Performance
Jane123
Post by Jane123 » Thu Oct 27, 2016 5:51 pm
The DS100BR410 is an extremely low power, high performance quad-channel repeater for high-speed serial links with data rates up to 10.3125 Gbps. The device performs both receive equalization and transmit de-emphasis on each of its 4 channels to compensate for channel loss, allowing maximum flexibility of physical placement within a system.
The receiver’s continuous time linear equalizer (CTLE) is capable of opening an input eye that is completely closed due to inter-symbol interference (ISI) induced by the interconnect medium such as backplane trace or cable. The transmitter features adjustable VOD (output amplitude voltage level) and de-emphasis driver to compensate for PCB trace lost.
With a low power consumption and control to turn-off unused channels, the DS100BR410 is part of National’s PowerWise family of energy efficient devices.
The programmable settings can be applied via pin mode or SMBus mode interface.
Features:
Quad channel repeater for up to 10.3125 Gbps
Low power consumption, with option to power down unused channels
Adjustable receive equalization
Adjustable transmit de-emphasis
Adjustable transmit VOD (up to 1200 mVp-p)
IDLE detection — squelch function auto mutes the output for SATA/SAS OOB signal.
<0.22 UI of residual DJ at 10.3125 Gbps with 12 meters cable
Programmable via pin selection or SMBus interface
Single supply operation at 2.5 V ±5%
-40°C to +85°C Operation
≥7 kV HBM ESD Rating
High speed signal flow–thru pinout package: 48-pin LLP (7 mm x 7 mm, 0.5 mm pitch)
