Hey brad for the 8x8 game system do you have to use the 1/4 watt 150ohm resistor or can you use a 1/2 watt 150ohm resistor
Resistors
Re: Resistors
any resistor will be fine 1/8 watt or 1/4 watt or 1/2 watt or even big 1 watt resistors! (I recommend 1/4 watt because they fit nicely though)
- 1kiko1
- Joined: Wed Jun 29, 2011 11:16 pm [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Resistors
Thanks yea the 1/4 fit in better than the 1/2
