Power Question
QuakerDeuce
Power Question
Post by QuakerDeuce » Fri Feb 18, 2011 10:59 am
Hi Brad,
Thanks so much for the instructables for the project, everything looks great. I had a quick question about the power. You have mentioned that you need a 7.5V power supply for the board, but that it can be up to 18V. Is there a problem with just attaching a 9V battery to the board itself? This way you could bypass all the power transfer issues.
Thanks!
Re: Power Question
Post by brad » Fri Feb 18, 2011 11:39 am
That would be just fine.
Just connect your 9v battery to the regulator and then you will get a nice steady 5v output.
The power transfer method just gets rid of the problem of the battery going dead.
QuakerDeuce
Re: Power Question
Post by QuakerDeuce » Tue Feb 22, 2011 3:53 am
Ah I see. Thanks for the quick response.
Do you happen to know the speed of your DC motor (rpm's) and the current that it draws?
Thanks!
Re: Power Question
Post by brad » Tue Feb 22, 2011 8:53 pm
I'm not sure how fast the motor spins, I just connected it up to a 12v 1.5A power supply and it spun fast enough to have just about no flicker.
If the image doesn't look quite right, you can adjust the LED on and off times in the included software.
Re: Power Question
Post by MrDEB » Sun Feb 27, 2011 7:30 am
Dang It all Now I can't find the link for doing graphics using an EXCEL sheet?
Saw it this morning
Re: Power Question
Post by brad » Sun Feb 27, 2011 8:16 pm
