EEPROM and Binary Counter
Hey all,
Heres the souce code
http://www.bradsprojects.com/phpBB2/upl ... v1_174.asm
- binary_counter.jpg (45.59 KiB) Viewed 13374 times
- Binary counter.jpg (45.1 KiB) Viewed 13406 times
- Binary Counting TutorialV1.asm
- (8.82 KiB) Downloaded 499 times
Heres the schematics
http://www.bradsprojects.com/phpBB2/upl ... er_170.zip
Note this schematics is for EAGLE
- Eeprom & Binary Counter.zip
- (13.71 KiB) Downloaded 556 times
- sdudley
- Moderator
What a great project!
I love projects that are quick, to the point, and do something useful. Definitely should become a tutorial!
I did not read through the code but had a quick look and love how nice and clean it is (makes for easy reading). I like to section off my routines just like you did.
I have always wanted to look into programming with eeprom storage. This is my chance!
Thank you.
Thank you.
Thanks Stacy
The souce code that I have uploaded is a basic start to eeprom and the way it works, you can change the souce code to select different eeprom addresses to store your data, and read your eeprom from your programmer, if you got a pickit2 this is quite easy.
I guess I should make a tutorial for it because before I started looking into eeprom on the microchip I didnt know where to start, took me awhile reading through the datasheet to understand it
- sdudley
- Moderator
I know exactly how you feel. I wanted to know about interrupts and could not find any plain and simple answers. Like you, I spent a LOT of time reading through the datasheet, asking questions on the Microchip forum and searching around.bitfogav wrote:...before I started looking into eeprom on the microchip I didnt know where to start, took me awhile reading through the datasheet to understand it
I just wanted a very basic tutorial on how an interrupt works and something so I could see it working. That is why I finally uploaded one to Brad's Projects University. I tried really hard to keep it as simple as possible.
I am excited to go through your code and see how to utilize eeprom in my projects!
For people who dont know much about eeprom then I recommend looking at this website
http://www.arlabs.com/help.htm
