It is currently Mon May 20, 2013 4:00 pm
Post new topic Reply to topic  [ 4 posts ]
 Post subject: http://www.sureelectronics.net/goods.php?id=230
PostPosted: Fri May 11, 2012 10:31 pm
Hi Brad! I have ordered these, but it shows that it's only green dot , is it normal? maybe it's the connection?..
i have perfectly followed the schematic on the great race??
thanks!
marC:)
 Post subject: Re: http://www.sureelectronics.net/goods.php?id=230
PostPosted: Sat May 12, 2012 2:45 am
Quote:
10pcs 8x8 Dot-Matrix 3mm dia. Bicolor LED Display (LE-MM103)
No they are the Bicolour ones, so I would double check your connections?. But note that the Great Race schematic only uses the lower Red Row of LEDs.
PostPosted: Sat May 12, 2012 4:31 am
and your smile does use red dot too?
how can i check the color of each dot ?
thanks!
marC:)
PostPosted: Sat May 12, 2012 5:04 am
All the information you will need about the 8x8 matrix is at the link below, I suggest you read through the topic and then you will get a better understanding on how the 8x8 Matrix works.
http://www.bradsprojects.com/forum/viewtopic.php?f=2&t=250&start=0
