can i havfull source of santa scrabble for pic16f628a please
- Joined: Wed Jan 25, 2012 2:54 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi!
I would like to have the full source of santa scrabble for pic16f628a game, or only the .hex file with the pic16f628a firmwire..
http://www.instructables.com/id/Christm ... /?ALLSTEPS
would be great Brad!
thanks so much!
marC:)
thanks so much!
marC:)
Re: can i havfull source of santa scrabble for pic16f628a pl
Unfortunately I don't have the sourcecode anymore.
I only have the hex file. It is very similar to the great race though if you wanted to have a look at that one.
can i burn the .hex into a pic16f628a?brad wrote:Unfortunately I don't have the sourcecode anymore.
would this work?
thanks!
marC:)
Unfortunately not. The 628a / 648a chips don't have enough I/O ports to make it work.
i think i have ordered the wrong matrix, it's all green dot, so i cannot see the red dot, so ... i would think of buying this one : http://www.sparkfun.com/products/681, is it okay for this game?brad wrote:Unfortunately not. The 628a / 648a chips don't have enough I/O ports to make it work.
do i need to buy a common cathode or common anode?
thanks brad!
marC:)
Could you post a photo of the underside of your matrix?
here is it : http://www.sparkfun.com/products/681brad wrote:Could you post a photo of the underside of your matrix?
thanks!
marC:)
here's for you brad : http://retfie.com/bottom.jpgnodoubtman wrote:here is it : http://www.sparkfun.com/products/681brad wrote:Could you post a photo of the underside of your matrix?
thanks!
marC:)
Just to note that those sparkfun matrix's are Common Cathode. you need Common Anode!.
Description: LED Matrix with dual-color LEDs. This small matrix has both bright-red and bright-green LEDs built into one common cathode housing.
I've never seen those in the common cathode variety!
