It is currently Wed May 22, 2013 3:20 pm
Post new topic Reply to topic  [ 11 posts ]
 Post subject: Setting up code for other pic microcontrolers.
PostPosted: Sat Apr 21, 2012 1:12 pm
semi-newbie
semi-newbie
hi brad!
i wanted to ask if you would be able to help me get my chip working.
i have been messing around with this 18f4680 and cant seem to get it to work.
do you think it would be possible to help me with this problem?
what i need to know is how to start my code.
i know i first set witch chip im using
LIST p=18f4680
include "P18f4680.inc"
but from there im not to sure how to set the default configuration and set my PORTB to outputs.
i would be happy to get a single led to flash and from there i can move foreward
 Post subject: Re: Setting up code for other pic microcontrolers.
PostPosted: Sat Apr 21, 2012 7:14 pm
I think Brad would agree with me if you are a beginner, the 18F microchip is a powerful microchip, I would look at using the Swordfish language especially has you are using a 18F microcontroller, Swordfish Basic is dedicated the 18F family of the microchip.
For Assembly Language you would probably need something like this after
LIST p=18f4680
Example:
Code:
   CONFIG WDT=OFF     ; disable watchdog timer
   CONFIG MCLRE = ON  ; MCLEAR Pin on
   CONFIG DEBUG = ON  ; Enable Debug Mode
   CONFIG LVP = OFF    ; Low-Voltage programming disabled (necessary for debugging)
   CONFIG FOSC = INTOSCIO_EC  ;Internal oscillator, port function on RA6
Look here!:
Swordfish IDE
You can also get a free version of the IDE which is only limited to the amount of RAM you can use!
which you can find here:
Swordfish SE
If you really want to get into Swordfish then you can find some great Code examples here Digital-DIY.com:
SF Code Examples
The code for flashing a LED is simple has this:
Code:
Device = 18F4680
Clock = 8
Config OSC = INTIO67                // Use the Internal Oscillator
Include "utils.bas"
Dim LED As PORTA.0                  // Assign an alias for "LED"
// Start Of Program...
OSCCON = %01111111                  // Sets up the internal oscillator
SetAllDigital                       // Make all Pins digital I/O's
Low(LED)                            // Make the LED pin an output and set it low
While True
High(Led)                          // Turn on the LED
DelayMS(500)                       // Delay for half a second
Low(Led)                           // Turn off the LED
Gavin
PostPosted: Tue Apr 24, 2012 4:01 am
semi-newbie
semi-newbie
wow thanks for the help.
i am using the swordfish ide now. it works great!
i have only one problem im running in to...
i am able to declare and initialize a constant array in a single line of code like this:
Code:
     const array(5) as bit = (0,0,0,0,0)
but that does not work for the variable array.
i can declare it but there is no way to initialize all its members in one go like the constant array.
is there a way around this?
PostPosted: Tue Apr 24, 2012 4:12 am
Im glad you found it useful, I enjoy Swordfish way more than Assembly :)
Code:
Yep there is several ways you can do this..
you can initialise each Array element by
Code:
Array(1) = 10
Array(2) = 10
Array(3) = 10
Array(4) = 10
Or something along the lines of this
Code:
dim Array(5) as byte
dim Index as byte
for Index = 0 to 5
   Array(Index) = 2
next
so each element of your array will now = 2
PostPosted: Tue Apr 24, 2012 4:19 am
semi-newbie
semi-newbie
Code:
Array(1) = 10
Array(2) = 10
Array(3) = 10
Array(4) = 10
Code:
dim Index as byte
for Index = 0 to 5
   Array(Index) = 2
next
but lets say i wanted the array to hold data that is not all the same and it was a very large array so i didn't want to write it as
Code:
Array(1) = 0
Array(2) = 1
Array(3) = 1
Array(4) = 0
etc...
Array(30) = 1
cause that would take up too many lines as apposed to
Code:
dim Array(16) as bit = (0,0,0,1,1,1,0,0,0,1,0,1,0,0,0,0,0,0,0,1,1,0,0,0,0,0,1,0,0,0,0,0)
but the above code is not valid
PostPosted: Tue Apr 24, 2012 4:36 am
Array(1) = 0
Array(2) = 1
Array(3) = 1
Array(4) = 0
etc...
Array(30) = 1
Sadly in Swordfish you cant Intialise Arrays the same way as a Constant Array.
So we are either left with typing out every line of the Array or we use a Repetitive statement for example a FOR Loop.
It looks like you have an Bit Array so something like this?
Code:
Dim Index as byte
Dim Array(16) as bit
For Index = 0 to bound(Array)
    If Index = 1 Or Index = 2 Or Index = 4 Or Index = 9 Or Index = 16 then
        Array(Index) = 1
    Else
        Array(Index) = 0
Next
So in the example above. Array(1),Array(2),Array(4),Array(9),Array(16) = 1
all other Array elements will = 0
Note that the first element of an array is located at 0, the second element at 1 and so on. Because Swordfish arrays begin with zero indexes.
so the Array code above will output something like this (0,1,1,0,1,0,0,0,0,1,0,0,0,0,0,0,1)
PostPosted: Tue Apr 24, 2012 6:26 am
This is how I do it:
I set up a constant array with my data, then my variable arrays (which will initially contain no data) I then run a loop to fill the variables with data from my const array:
Code:
const MyData(8) as bit = (1, 0, 1, 1, 0, 0, 0, 1)
dim MyVariableData(8) as bit
dim x as byte
for x  = 0 to 7
     MyVariableData(x) = MyData(x)
next
Swordfish is a fantastic language. I am working on a project at the moment using swordfish and it is alot more fun and fluid than assembly.
PostPosted: Tue Apr 24, 2012 2:36 pm
Or, you could be a little bit fancy and store the data in a single constant and then grab each bit from it.
Code:
Const MyData as word = %1011101001001011
Dim MyVariable(16) as bit
Dim x as byte
For x = 0 to 15
     MyVariable(x) = MyData.bits(x)
Next
PostPosted: Sun May 13, 2012 8:54 am
semi-newbie
semi-newbie
thanks alot for the help guys i was able to get my project working great now :] i will post some pics of it soon
PostPosted: Sun May 13, 2012 8:58 am
Your welcome, look forward to seeing your project :)
PostPosted: Sat May 19, 2012 1:42 pm
Me too!
