It is currently Tue May 21, 2013 12:01 am
Post new topic Reply to topic  [ 5 posts ]
 Post subject: Converting Decimal to Binary VB2010
PostPosted: Fri Nov 04, 2011 4:02 am
I was looking for a way to convert a Decimal number to Binary in VB 2010. So wrote the following function.
It will convert decimal integer values to a binary string, you also have the option to set the number of bits the function returns, by default the function will return 8 bits.
For example:
Code:
Dim myDec As Integer
myDec = 146
textbox1.Text = DecToBin(myDec)
' will return Binary 10010010
Or we could set the number of bits to return like this
Code:
myDec = 146
textbox1.Text = DecToBin(myDec, 16)
' will return Binary 0000000010010010
Code:
   Public Function DecToBin(ByVal DeciValue As Long, Optional ByVal NoOfBits As Integer = 8) As String
        Dim i As Integer
        Do While DeciValue > (2 ^ NoOfBits) - 1
            NoOfBits = NoOfBits + 8
        Loop
        DecToBin = vbNullString
        For i = 0 To (NoOfBits - 1)
            DecToBin = CStr((DeciValue And 2 ^ i) / 2 ^ i) & DecToBin
        Next i
    End Function
 Post subject: Re: Converting Decimal to Binary VB2010
PostPosted: Fri Nov 04, 2011 7:48 am
Just incase you want to convert a Binary number back to Decimal:
Code:
    ' builds a decimal number from a binary string.
    Public Function BinToDec(ByVal Binary As String) As Long
        Dim n As Long
        Dim s As Integer
        For s = 1 To Len(Binary)
            n = n + (Mid(Binary, Len(Binary) - s + 1, 1) * (2 ^ (s - 1)))
        Next s
        BinToDec = n
    End Function
PostPosted: Mon Nov 07, 2011 11:50 am
very handy!
I am surprised it doesn't have that sort of functionality built in?
PostPosted: Tue Nov 08, 2011 5:20 am
I spent quite awhile looking for a function in VB for Binary conversions but no luck!
Found some for Decimal to HEX though :)
PostPosted: Sat Nov 12, 2011 6:10 am
Speaking of conversions - I have been giving lectures on that sort of thing just this week :D
