Homework 1 Example...
Mike M
Post by Mike M » Sun Jan 06, 2013 10:30 am
This may not have been a good idea (lol). I ended up using a number of 'tricks' to optimize the size of the program, like using an in-line table, which, when compared to a traditional table, only saves one word of program memory and one stack level. Anyway, the program uses 30 words of program memory and 1 byte of RAM but it's probably incomprehensible for beginning programmers. Sorry! I can't help myself (lol).
Cheerful regards, Mike
;  Homework #1: 8x8 Smiley Face        Mike McLaren, 05-Jan-2013  *
   include "P16f648a.inc"
   __config _WDT_OFF&_LVP_OFF&_MCLRE_OFF&_BOREN_OFF&_INTOSC_OSC_NOCLKOUT
   list st=off          ; turn symbol table off in LST file
   errorlevel -302      ; disable bank warning messages
   radix dec            ; use decimal numbers
;  variables
        cblock 0x20
delayhi                 ; delay sub variable
        endc
;  main init                                                      *
        org     0x000
init
        clrf    STATUS          ; bank 0                          |B0
        movlw   h'07'           ;                                 |B0
        movwf   CMCON           ; comparator off, digital I/O     |B0
        movwf   PORTA           ; preset 7442 address to 7        |B0
        bsf     STATUS,RP0      ; bank 1                          |B1
        clrf    TRISA           ; porta all outputs, except RA5   |B1
        clrf    TRISB           ; portb all outputs               |B1
        bcf     STATUS,RP0      ; bank 0                          |B0
;  main loop                                                      *
loop
        clrf    PORTB           ; blank the display               |B0
        incf    PORTA,W         ; bump 7442 address (and index)   |B0
        andlw   7               ; keep in 0..7, inclusive         |B0
        movwf   PORTA           ; select new column               |B0
        addwf   PCL,F           ; jump into the "in-line" table   |B0
        xorlw   0^b'00111100'^(1^b'01000010')
        xorlw   1^b'01000010'^(2^b'10101001')
        xorlw   2^b'10101001'^(3^b'10000101')
        xorlw   3^b'10000101'^(4^b'10000101')
        xorlw   4^b'10000101'^(5^b'10101001')
        xorlw   5^b'10101001'^(6^b'01000010')
        xorlw   6^b'01000010'^(7^b'00111100')
        xorlw   7^b'00111100'   ;
        movwf   PORTB           ; display new column              |B0
;  delay subsystem range is 7..327682 usecs in 5 usec steps but
;  we'll use 1000 usecs per column for a 125 Hz refresh rate
        movlw   high((1000-7)/5)+1
        movwf   delayhi
        movlw   low ((1000-7)/5)
v2delay addlw   -1              ; subtract 5 cycle loop time      |B0
        skpc                    ; borrow? no, skip, else          |B0
        decfsz  delayhi,F       ; done?  yes, skip, else          |B0
        goto    v2delay         ; do another 5 cycle loop         |B0
        goto    loop            ; branch (loop forever)           |B0
        end
Re: Homework 1 Example...
Post by brad » Sun Jan 06, 2013 6:53 pm
Well done Mike - the first person to submit their homework to me in years!
Excellent coding there and now that I have learned a few other languages since writing the ASM tutorials, I can see how my new languages can actually help if I go back to using ASM. Once again, very well done :)
