Tutorial 7 - All the info you need is right here!
- Joined: Mon Aug 30, 2010 8:05 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: Tutorial 7 - All the info you need is right here!
Hey brad the other day I tried to change the track data from the great race but when I saved it all the code turned into black and when I tried to make it a hex file (quickbuild) It said that there was no asm file
That is really strange.
Can you post the modified code here in the forum, i'll have a look at it.
- Joined: Wed Jan 25, 2012 2:54 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Hi Brad!brad wrote:Yep, they will do the trick. You will find different variations in the part number but as long as it has 74373 written in there, it will be fine.
I would like to write my name on this 8x8 matrix?
how can i do that?
Thanks!
marC:)
Have a look at the great race code. In there is the track data (contained within the retlw statements) you can see the track drawn in the retlw statements with the binary 1's and 0's. To write your name, just modify the 1's and 0's.
You can then modify the code a bit to get rid of the game part and it will now just scroll your name instead.
ok! brad, thanks.. i will try to modify slighly the code, but i don't garanteed anithing!brad wrote:Have a look at the great race code. In there is the track data (contained within the retlw statements) you can see the track drawn in the retlw statements with the binary 1's and 0's. To write your name, just modify the 1's and 0's.
ehhe
Cya!
Let me know how you go!
santa scrabble is the same schematic as the great race??brad wrote:Let me know how you go!
thanks!
marC:)
Brad i give up for now, it's too difficult thanks for helping!nodoubtman wrote:santa scrabble is the same schematic as the great race??brad wrote:Let me know how you go!
thanks!
marC:)
marC:)
No Problem - start small and then work your way up. That's how I did it!
BUT? Brad, santa scrabble is the same schematic as the great race??brad wrote:No Problem - start small and then work your way up. That's how I did it!
thanks!
CYa!
marC if your still having problems with coding the Assembly code then try this?
It should scroll 1,2,3,4,5,6,7,8,9 Ive commented the section of code that you need to change if you want the matrix to say something else?
Gavin
Gavin
thank you!bitfogav wrote:marC if your still having problems with coding the Assembly code then try this?
Gavin
marC:)
Is it possible to make it scroll bicolor ?bitfogav wrote:marC if your still having problems with coding the Assembly code then try this?
Gavin
thanks!
marC:)
The Great Race and Santa’s Scramble schematic was only designed to use one colour. if you want a scrolling Matrix that uses bicolour then you might have to look at making a circuit like the 8x8 Game System.nodoubtman wrote:Is it possible to make it scroll bicolor ?
thanks!
marC:)
ok, so the santa's scramble is using the same schematic right?bitfogav wrote:The Great Race and Santa’s Scramble schematic was only designed to use one colour. if you want a scrolling Matrix that uses bicolour then you might have to look at making a circuit like the 8x8 Game System.nodoubtman wrote:Is it possible to make it scroll bicolor ?
thanks!
marC:)
thanks!
marC:)
