It is currently Thu Jun 20, 2013 10:51 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Tutorial 7 - All the info you need is right here!
PostPosted: Thu Aug 11, 2011 7:13 am
Hey brad the other day I tried to change the track data from the great race but when I saved it all the code turned into black and when I tried to make it a hex file (quickbuild) It said that there was no asm file
PostPosted: Thu Aug 11, 2011 9:52 pm
That is really strange.
Can you post the modified code here in the forum, i'll have a look at it.
PostPosted: Fri May 11, 2012 12:09 am
brad wrote:
Yep, they will do the trick. You will find different variations in the part number but as long as it has 74373 written in there, it will be fine.
Hi Brad! :)
I would like to write my name on this 8x8 matrix?
how can i do that?
Thanks!
marC:)
PostPosted: Fri May 11, 2012 8:14 am
Have a look at the great race code. In there is the track data (contained within the retlw statements) you can see the track drawn in the retlw statements with the binary 1's and 0's. To write your name, just modify the 1's and 0's.
You can then modify the code a bit to get rid of the game part and it will now just scroll your name instead.
PostPosted: Fri May 11, 2012 11:53 am
ok! :) brad, thanks.. i will try to modify slighly the code, but i don't garanteed anithing! :)
ehhe
Cya!
PostPosted: Fri May 11, 2012 12:17 pm
Let me know how you go!
PostPosted: Sat May 12, 2012 8:22 am
santa scrabble is the same schematic as the great race??
thanks!
marC:)
PostPosted: Sat May 12, 2012 12:27 pm
thanks!
marC:)
Brad i give up for now, it's too difficult thanks for helping!
marC:)
PostPosted: Sun May 13, 2012 10:06 am
No Problem - start small and then work your way up. That's how I did it!
PostPosted: Wed May 16, 2012 5:01 am
BUT? Brad, santa scrabble is the same schematic as the great race??
thanks!
CYa!
PostPosted: Wed May 16, 2012 6:33 am
marC if your still having problems with coding the Assembly code then try this?
The Scroller.asm [15.51 KiB]
Downloaded 50 times
It should scroll 1,2,3,4,5,6,7,8,9 Ive commented the section of code that you need to change if you want the matrix to say something else?
Gavin
PostPosted: Thu May 17, 2012 12:42 am
The Scroller.asm
Gavin
thank you!
marC:)
PostPosted: Thu May 17, 2012 3:44 am
The Scroller.asm
Gavin
Is it possible to make it scroll bicolor ?
thanks!
marC:)
PostPosted: Thu May 17, 2012 4:09 am
thanks!
marC:)
The Great Race and Santa’s Scramble schematic was only designed to use one colour. if you want a scrolling Matrix that uses bicolour then you might have to look at making a circuit like the 8x8 Game System.
PostPosted: Thu May 17, 2012 4:17 am
bitfogav wrote:
thanks!
marC:)
ok, so the santa's scramble is using the same schematic right?
thanks!
marC:)
