Write longer messages on Matrix
Posted: Thu Aug 23, 2012 11:15 pm
I would like to write longer message like this :
'Marc Paradis électronique ', but it cuts in after the u ' and loop back i don't know why, i would like to write some complete sentences, is there a way? thanks a bunch!
thanks for the big help!
marC:)
*EDITED By Bitfogav - moved to new topic*
; The scroller ;
; this is made for the 8x8 display ;
LIST p=16f628a ; tell assembler what chip we are using
include "P16f628a.inc" ; include the defaults for the chip
__config 0x3f18 ; sets the configuration settings (oscillator type etc.)
errorlevel -302
PC equ 0x02 ; The program counter will be refered to as PC
cblock 0x20 ; start of general purpose registers - this is where we start defining variable names
counta ; used in the delay routines
countb ; used in the delay routines
pc_track ; this is our track data program counter
vram_1 ; a video ram location
vram_2 ; a video ram location
vram_3 ; a video ram location
vram_4 ; a video ram location
vram_5 ; a video ram location
vram_6 ; a video ram location
vram_7 ; a video ram location
vram_8 ; a video ram location
vtemp_1 ; a temporary video ram location (used when tranfering vram data to the next vram location)
vtemp_2 ; a temporary video ram location (used when tranfering vram data to the next vram location)
vtemp_3 ; a temporary video ram location (used when tranfering vram data to the next vram location)
vtemp_4 ; a temporary video ram location (used when tranfering vram data to the next vram location)
vtemp_5 ; a temporary video ram location (used when tranfering vram data to the next vram location)
vtemp_6 ; a temporary video ram location (used when tranfering vram data to the next vram location)
vtemp_7 ; a temporary video ram location (used when tranfering vram data to the next vram location)
repeat_frame ; used to determine how many times we will be repeating each 'frame'
endc ; end of general purpose registers
org 0x0000 ; org sets the origin, 0x0000 for the 16F628,
movlw h'07' ; Turn comparators off
movwf CMCON ; (we just want to use the ports as digital ports)
bsf STATUS, RP0 ; select bank 1 (to enable us to change the Input / Output status of our ports)
movlw b'00000000' ; set PORTB all outputs (A '0' means output, A '1' means input. We can set each
movwf TRISB ; We can set each bit individualy. Each port having 8-bits or 8 pins.
movlw b'00100000' ; set PORTA all outputs except for bit 5. Bit 5 is an input ONLY pin.
movwf TRISA ; It cannot be set to an output!
bcf STATUS, RP0 ; select bank 0
goto setup ; go straight to the setup routine
track_message ; Here's our letter data!
incf pc_track, f ; increment pc_track by one and then
movf pc_track, w ; move it into our working register THEN
addwf PC ; add this number to our program counter
nop ; skip one step...
; Draw data on matrix
; HERE IS WHERE YOU ENTER YOUR DATA TO DISPLAY ON THE 8x8 MATRIX
retlw b'00000000'
retlw b'00000000'
retlw b'00000000' ; space before we draw the data on the Matrix
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; m
retlw b'00000000'
retlw b'01101100'
retlw b'01011100'
retlw b'01010100'
retlw b'01010100'
retlw b'01000100'
retlw b'01000100'
retlw b'00000000'
retlw b'00000000' ; space between numbers
retlw b'00000000'
; a
retlw b'00000000'
retlw b'01111100'
retlw b'01000100'
retlw b'01111100'
retlw b'01000100'
retlw b'01000100'
retlw b'01000100'
retlw b'00000000'
retlw b'00000000'
; r
retlw b'00000000'
retlw b'01111100'
retlw b'01000100'
retlw b'01001000'
retlw b'01010000'
retlw b'01001000'
retlw b'01000100'
retlw b'00000000'
retlw b'00000000'
; c
retlw b'00000000'
retlw b'01111100'
retlw b'01000000'
retlw b'01000000'
retlw b'01000000'
retlw b'01000000'
retlw b'01111100'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; p
retlw b'00000000'
retlw b'01111100'
retlw b'01000100'
retlw b'01001000'
retlw b'01110000'
retlw b'01000000'
retlw b'01000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; a
retlw b'00000000'
retlw b'01111100'
retlw b'01000100'
retlw b'01111100'
retlw b'01000100'
retlw b'01000100'
retlw b'01000100'
retlw b'00000000'
retlw b'00000000'
; r
retlw b'00000000'
retlw b'01111100'
retlw b'01000100'
retlw b'01001000'
retlw b'01010000'
retlw b'01001000'
retlw b'01000100'
retlw b'00000000'
retlw b'00000000'
; a
retlw b'00000000'
retlw b'01111100'
retlw b'01000100'
retlw b'01111100'
retlw b'01000100'
retlw b'01000100'
retlw b'01000100'
retlw b'00000000'
retlw b'00000000'
; d
retlw b'00000100'
retlw b'00000100'
retlw b'00000100'
retlw b'00111100'
retlw b'01000100'
retlw b'01000100'
retlw b'01111100'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; i
retlw b'00000000'
retlw b'00010000'
retlw b'00000000'
retlw b'00010000'
retlw b'00010000'
retlw b'00010000'
retlw b'00010000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; s
retlw b'00000000'
retlw b'01111000'
retlw b'01000000'
retlw b'01000000'
retlw b'00111000'
retlw b'00001000'
retlw b'01111000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; e
retlw b'00000000'
retlw b'01111100'
retlw b'01000000'
retlw b'01000000'
retlw b'01110000'
retlw b'01000000'
retlw b'01111100'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; l
retlw b'00000000'
retlw b'00100000'
retlw b'00100000'
retlw b'00100000'
retlw b'00100000'
retlw b'00100000'
retlw b'00111100'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; e
retlw b'00000000'
retlw b'01111100'
retlw b'01000000'
retlw b'01000000'
retlw b'01110000'
retlw b'01000000'
retlw b'01111100'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; c
retlw b'00000000'
retlw b'01111100'
retlw b'01000000'
retlw b'01000000'
retlw b'01000000'
retlw b'01000000'
retlw b'01111100'
retlw b'00000000'
retlw b'00000000'
; t
retlw b'00000000'
retlw b'01111100'
retlw b'00010000'
retlw b'00010000'
retlw b'00010000'
retlw b'00010000'
retlw b'00010000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; r
retlw b'00000000'
retlw b'01111100'
retlw b'01000100'
retlw b'01001000'
retlw b'01010000'
retlw b'01001000'
retlw b'01000100'
retlw b'00000000'
retlw b'00000000'
; o
retlw b'00000000'
retlw b'01111100'
retlw b'01000100'
retlw b'01000100'
retlw b'01000100'
retlw b'01000100'
retlw b'01111100'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; n
retlw b'00000000'
retlw b'00000000'
retlw b'01000000'
retlw b'01111000'
retlw b'01001000'
retlw b'01001000'
retlw b'01001000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; i
retlw b'00000000'
retlw b'00010000'
retlw b'00000000'
retlw b'00010000'
retlw b'00010000'
retlw b'00010000'
retlw b'00010000'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; q
retlw b'00000000'
retlw b'01111100'
retlw b'01000100'
retlw b'01000100'
retlw b'01111100'
retlw b'00000100'
retlw b'00000100'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; u
retlw b'00000000'
retlw b'00100100'
retlw b'00100100'
retlw b'00100100'
retlw b'00100100'
retlw b'00100100'
retlw b'00111100'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; e
retlw b'00000000'
retlw b'01111100'
retlw b'01000000'
retlw b'01000000'
retlw b'01110000'
retlw b'01000000'
retlw b'01111100'
retlw b'00000000'
retlw b'00000000'
retlw b'00000000'
; brad smile
retlw b'00111100'
retlw b'01000010'
retlw b'10100101'
retlw b'10000001'
retlw b'10100101'
retlw b'10011001'
retlw b'01000010'
retlw b'00111100'
retlw b'00000000'
retlw b'00000000'
; END OF DATA
setup ; Okay, lets get everything setup, ready to play!
movlw b'00000000' ; setup PORTA so that the 7442 ports are all ground inputs.
movwf PORTA ; and also send out a logic 1 to the red column of led cathodes (so they wont turn on)
clrf PORTB ; we dont want any data on the screen just yet - so clear PORTB
clrf vram_1 ; these next lines clear our video ram.
clrf vram_2 ; if we didnt clear them, then we would get random
clrf vram_3 ; dots on our screen at startup and would more than likely crash
clrf vram_4 ; as soon as we started playing! (experiment with not
clrf vram_5 ; clearing all these vrams and see what happens!)
clrf vram_6 ; ....
clrf vram_7 ; ....
clrf vram_8 ; ....
clrf pc_track ; clear pc_track (so we start from the top of this data
begin ; the main program!
call display ; call the display routine
call fill_vram ; call the fill video ram routine
goto begin ; do it all again!
; The next routine basically takes care of drawing the actual ;
; graphics on the screen. You will notice that there are eight ;
; "sections" here'. they basically look the same except for ;
; minor differences. Thats because they are all doing the same ;
; thing - activating a certain row of cathodes and then grabbing ;
; the anode data in order to turn the leds on. The only ;
; difference between them is that each section activates a ;
; different row of cathodes and also grabs it's data to be ;
; displayed from a different vram location. ;
display
movlw d'25' ; We need to set the speed that we are scrolling at,
movwf repeat_frame ; so we grab that data from speed and copy it to our frame_rate
loop
movlw b'00000111'
movwf PORTA
movf vram_1, w ; Now we grab the first COLUMN of data from vram_1.
movwf PORTB ; then we copy it to PORTB
call delay ; Call the delay (to hold that one row ON for a split second)
clrf PORTB
movlw b'00000110'
movwf PORTA
movf vram_2, w ; Now we grab the first COLUMN of data from vram_1.
clrf PORTB
movlw b'00000101'
movwf PORTA
movf vram_3, w ; Now we grab the first COLUMN of data from vram_1.
clrf PORTB
movlw b'00000100'
movwf PORTA
movf vram_4, w ; Now we grab the first COLUMN of data from vram_1.
clrf PORTB
movlw b'00000011'
movwf PORTA
movf vram_5, w ; Now we grab the first COLUMN of data from vram_1.
clrf PORTB
movlw b'00000010'
movwf PORTA
movf vram_6, w ; Now we grab the first COLUMN of data from vram_1.
clrf PORTB
movlw b'00000001'
movwf PORTA
movf vram_7, w ; Now we grab the first COLUMN of data from vram_1.
clrf PORTB
movlw b'00000000'
movwf PORTA
movf vram_8, w ; Now we grab the first COLUMN of data from vram_1.
clrf PORTB
decfsz repeat_frame ; then decrease repeat_frame by one,
goto loop ; if its not zero then draw it all again!
return ; if it is zero, then go back to where we came from...
; This next section basically 'fills' the video ram locations ;
; with the data from the previous video ram location - This is ;
; how we get the screen to scroll. It also grabs a new byte of ;
; data from the track data table to display in video ram 1. ;
fill_vram
movf vram_1, 0 ; Copy vram_1 into vtemp_1 to use as a backup
movwf vtemp_1 ; storage location. (just before we overwrite vram_1)
movf vram_2, 0 ; Copy vram_1 into vtemp_2 to use as a backup
movwf vtemp_2 ; storage location. (just before we overwrite vram_2)
movf vram_3, 0 ; Copy vram_1 into vtemp_3 to use as a backup
movwf vtemp_3 ; storage location. (just before we overwrite vram_3)
movf vram_4, 0 ; Copy vram_1 into vtemp_4 to use as a backup
movwf vtemp_4 ; storage location. (just before we overwrite vram_4)
movf vram_5, 0 ; Copy vram_1 into vtemp_5 to use as a backup
movwf vtemp_5 ; storage location. (just before we overwrite vram_5)
movf vram_6, 0 ; Copy vram_1 into vtemp_6 to use as a backup
movwf vtemp_6 ; storage location. (just before we overwrite vram_6)
movf vram_7, 0 ; Copy vram_7 into vtemp_7 to use as a backup
movwf vtemp_7 ; storage location. (just before we overwrite vram_7)
; Did you notice that we don't need to make a backup of vram_8? ;
; That's because there are only 8 lines on the screen. So after ;
; we display the 8th line, it is then shifted out of the screen. ;
; Now that we have backed up our old vram data, we then need to ;
; copy them to the next successive vram location - this basically ;
; shifts everything on the screen down one space. It also grabs ;
; a brand new byte of data and copies it into vram_1 (which ;
; means it will be displayed at the top of the screen, before ;
; It gets shifted again... ;
call track_message
movwf vram_1 ; then copy the new byte of data to the first vram location
movf vtemp_1, 0 ; copy what was in vram_1 into vram_2 (remember how we made
movwf vram_2 ; a backup of vram_1 and called it vtemp_1.)
movf vtemp_2, 0 ; copy what was in vram_2 into vram_3 (remember how we made
movwf vram_3 ; a backup of vram_2 and called it vtemp_2.)
movf vtemp_3, 0 ; copy what was in vram_3 into vram_4 (remember how we made
movwf vram_4 ; a backup of vram_3 and called it vtemp_3.)
movf vtemp_4, 0 ; copy what was in vram_4 into vram_5 (remember how we made
movwf vram_5 ; a backup of vram_4 and called it vtemp_4.)
movf vtemp_5, 0 ; copy what was in vram_5 into vram_6 (remember how we made
movwf vram_6 ; a backup of vram_5 and called it vtemp_5.)
movf vtemp_6, 0 ; copy what was in vram_6 into vram_7 (remember how we made
movwf vram_7 ; a backup of vram_6 and called it vtemp_6.)
movf vtemp_7, 0 ; copy what was in vram_7 into vram_8 (remember how we made
movwf vram_8 ; a backup of vram_7 and called it vtemp_7.)
return ; Now that we're all done here, go back to our main program.
; Heres the delay routines! ;
delay ; This first delay is a rather fast one.
movlw d'02' ; You can make the delay longer by #### the higher the value, the more the matrix will flicker ####
movwf counta ; increasing the decimal value. Or you
movwf countb ; can make the delay shorter by decreasing
again decfsz counta, 1 ; the decimal value.
goto again ;
decfsz countb, 1 ;
goto again ; once counta and countb have reached zero
return ; it will return to the main program
end ; That's it!
marC:)
