Brads Electronic Projects Forum • CLAP CLAP circuit with RELAY OUTPUT
Posted: Thu Aug 02, 2012 3:30 am
by nodoubtman
hi! this is the asm code for a clap clap circuit, but unfortunaly it turns the relay no after two claps, is it possible to make it for one clap ? and can you provide me the code PLEASE for a single clap, thank you sooo much!!!!
marC:)
; This file is a basic code template for assembly code generation *
; on the PIC10F222. This file contains the basic code *
; building blocks to build upon. *
; Refer to the MPASM User's Guide for additional information on *
; features of the assembler (Document DS33014). *
; Refer to the respective PIC data sheet for additional *
; information on the instruction set. *
; Filename: xxx.asm *
; Date: JULY 17/11 *
; File Version: Rev.A *
; Author: Patrick Mitchell *
; Company: www.engineeringshock.com *
; Files Required: P10F222.INC *
; Notes: *
list p=10F222 ; list directive to define processor
#include <p10F222.inc> ; processor specific variable definitions
__CONFIG _MCLRE_OFF & _CP_OFF & _WDT_OFF & _MCPU_OFF & _IOFSCS_4MHZ
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
;***** VARIABLE DEFINITIONS
TEMP_VAR UDATA
TEMP1 RES 1 ;DELAY REGISTER1
TEMP2 RES 1 ;DELAY REGISTER2
TEMP3 RES 1 ;DELAY REGISTER3
TEMP4 RES 1 ;DELAY REGISTER4
TEMP5 RES 1 ;TIMING REGISTER
TEMP6 RES 1 ;TINING REGISTER
errorlevel -302 ; suppress message 302 from list file
ORG 0xFF ; processor reset vector
; Internal RC calibration value is placed at location 0xFF by Microchip
; as a movlw k, where the k is a literal value.
ORG 0x000 ; coding begins here
movwf OSCCAL ; update register with factory cal value
INITIALIZE
MOVLW B'1000' ; GPIO1=COMPARATOR IN - GPIO0-RELAY ACTIVATE
TRIS GPIO ; INITIALIZE
CLRF ADCON0 ; ADC DISABLE
CLRF GPIO
MOVLW B'00001000'
OPTION
CALL LOOP3
CLRF TEMP5
START:
CLRF GPIO
MOVLW B'01000001' ;analog i/p configuration
MOVWF ADCON0 ;setup GPIO,0 as ADC input
BSF ADCON0,GO ;take an ADC reading
WAITADC:
BTFSC ADCON0,GO ; poll for reading to complete
GOTO WAITADC ; if not done, keep polling
MOVLW B'00000001' ; place 01H in compare register
SUBWF ADRES,C ; compare instruction
BTFSC STATUS,C ; if ADC reading is more than 01H, a clap has been detected
GOTO NEXT ; if clap has been detected, to go NEXT routine
GOTO START ; if not, start from beginning of program
NEXT:
CALL LOOP3 ; delay
GOTO HI
;BCF STATUS,C ; clear STATUS flag so that we can use ADC again
;MOVLW 0XFF ; Place FFH in WREG
;MOVWF TEMP3 ; Place FFH into timing register - Will take the following steps up to 255 times (FF Hex)
NEXT2:
CALL LOOP1 ; short delay
BCF STATUS,C
MOVLW B'01000001' ; analog i/p configuration
MOVWF ADCON0 ; setup ADC
BSF ADCON0,GO ; Take an ADC reading
WAITADC2:
BTFSC ADCON0,GO ; poll for ADC reading to complete
GOTO WAITADC2 ; if not complete, poll again
MOVLW B'00000001' ; repeat same steps in earlier programming to look for second clap
SUBWF ADRES,C
BTFSC STATUS,C
GOTO HI ; if second clap is detected, to go step that turns on relay
DECFSZ TEMP3 ; if not, decrement countdown register and compare with 0
GOTO NEXT2 ; if timing register is not 0, repeat ADC reading
GOTO START ; if timing register = 0, restart program from scratch
OFF:
; the following set of routines follow the same programming as the first half of the program, only
; this time, we're looking for two claps that will turn the relay off
MOVWF ADCON0
BSF ADCON0,GO
WAITADC3:
BTFSC ADCON0,GO
GOTO WAITADC3
MOVLW B'00000001'
SUBWF ADRES,C
BTFSC STATUS,C
GOTO NEXT3
GOTO OFF
NEXT3:
CALL LOOP3
BCF STATUS,C
MOVLW 0XFF
MOVWF TEMP3
NEXT4:
CALL LOOP1
BCF STATUS,C
MOVWF ADCON0
BSF ADCON0,GO
WAITADC4:
BTFSC ADCON0,GO
GOTO WAITADC4
MOVLW B'00000001'
SUBWF ADRES,C
BTFSC STATUS,C
GOTO LO
DECFSZ TEMP3
GOTO NEXT4
GOTO OFF
HI:
; this routine turns the relay on
BSF GPIO,1
CALL LOOP3
GOTO OFF
LO:
; this routine turns the relay off
BCF GPIO,1
CALL LOOP1
GOTO INITIALIZE ; resets system to start from scratch
; *** LOOP1/2 Routines work together as a short delay routine
LOOP1:
MOVLW 0X00
MOVWF TEMP1
MOVLW 0X02
MOVWF TEMP2
LOOP2:
DECFSZ TEMP1
GOTO LOOP2
DECFSZ TEMP2
GOTO LOOP2
RETURN
; LOOP3/4 work together as a long delay routine
LOOP3:
MOVLW 0X00
MOVWF TEMP1
MOVLW 0X30
MOVWF TEMP2
LOOP4:
DECFSZ TEMP1
GOTO LOOP4
DECFSZ TEMP2
GOTO LOOP4
RETURN
END
Re: CLAP CLAP circuit with RELAY OUTPUT
Posted: Fri Aug 10, 2012 3:32 am
Why dont you see if you can change the programme yourself? :)
Ill give you a clue, you might want to remove this part of the code from within the code
NEXT2:
BCF STATUS,C
WAITADC2:
SUBWF ADRES,C
BTFSC STATUS,C
Posted: Thu Aug 16, 2012 4:38 am
by nodoubtman
bitfogav wrote:Why dont you see if you can change the programme yourself? :)
NEXT2:
BCF STATUS,C
WAITADC2:
SUBWF ADRES,C
BTFSC STATUS,C
i don't know assembly i will try thank you bigof! :)
marC:)
Posted: Thu Aug 16, 2012 4:44 am
by nodoubtman
I guess i will have to remove this part too ?? :
WAITADC3:
BTFSC ADCON0,GO
GOTO WAITADC3
MOVLW B'00000001'
SUBWF ADRES,C
BTFSC STATUS,C
GOTO NEXT3
GOTO OFF
NEXT3:
CALL LOOP3
BCF STATUS,C
MOVLW 0XFF
MOVWF TEMP3
NEXT4:
CALL LOOP1
BCF STATUS,C
MOVWF ADCON0
BSF ADCON0,GO
WAITADC4:
BTFSC ADCON0,GO
GOTO WAITADC4
MOVLW B'00000001'
SUBWF ADRES,C
BTFSC STATUS,C
GOTO LO
DECFSZ TEMP3
GOTO NEXT4
GOTO OFF
thanks!
marC:)
yes? :)
Posted: Thu Aug 16, 2012 5:08 am
nodoubtman wrote:i don't know assembly i will try thank you brad! :)
marC:)
We all had to start somewhere, Brads assembly tutorials are always a good place to start.
Brads Tutorials
nodoubtman wrote: I guess i will have to remove this part too ?? :
WAITADC3:
BTFSC ADCON0,GO
GOTO WAITADC3
MOVLW B'00000001'
SUBWF ADRES,C
BTFSC STATUS,C
GOTO NEXT3
GOTO OFF
NEXT3:
CALL LOOP3
BCF STATUS,C
MOVLW 0XFF
MOVWF TEMP3
NEXT4:
CALL LOOP1
BCF STATUS,C
MOVWF ADCON0
BSF ADCON0,GO
WAITADC4:
BTFSC ADCON0,GO
GOTO WAITADC4
MOVLW B'00000001'
SUBWF ADRES,C
BTFSC STATUS,C
GOTO LO
DECFSZ TEMP3
GOTO NEXT4
GOTO OFF
thanks!
marC:)
yes? :)
Yes you can remove that code aswell but you will need to come up with some code to turn off the relay after it has been activated.
Gavin :)
Posted: Thu Aug 16, 2012 5:23 am
by nodoubtman
HI:
BSF GPIO,1
CALL LOOP2
GOTO OFF
just put LOOP2 instead LOOP3 , is it okay?
LO:
BCF GPIO,1
CALL LOOP1
here's the full code for one single clap :
; Company: http://www.engineeringshock.com *
; Notes: *
TEMP_VAR UDATA
INITIALIZE
CLRF GPIO
MOVLW B'00001000'
OPTION
CALL LOOP1
CLRF TEMP5
START:
CLRF GPIO
WAITADC:
NEXT:
CALL LOOP2 ; delay
OFF:
MOVWF ADCON0
BSF ADCON0,GO
HI:
BSF GPIO,1
CALL LOOP2
GOTO OFF
LO:
BCF GPIO,1
CALL LOOP1
LOOP1:
MOVLW 0X00
MOVWF TEMP1
MOVLW 0X02
MOVWF TEMP2
LOOP2:
DECFSZ TEMP1
GOTO LOOP2
DECFSZ TEMP2
GOTO LOOP2
RETURN
END
is okay?
thanks!
marC:)
Posted: Thu Aug 16, 2012 6:25 am
This is probably what I would have done.
	cblock 0x09
		counta
		countb
		countc
	endc
INITIALIZE
	CLRF GPIO
	MOVLW B'00001000'
	OPTION
	NOP
	NOP
START:
	CLRF GPIO
	MOVWF ADCON0 		; setup GPIO,0 as ADC input
	BSF ADCON0,GO 		; take an ADC reading
WAITADC:
NEXT:
	CALL Delay255 		; delay
	GOTO HI
OFF:
	; this time, we're looking for one clap that will turn the relay off.
	MOVWF ADCON0
	BSF ADCON0,GO
WAITADC2:
	GOTO WAITADC2 		; if not done, keep polling
	GOTO NEXT2 			; if clap has been detected, to go NEXT2 routine
	GOTO WAITADC2	 	; if not, start from beginning of program
NEXT2:
	GOTO LO
HI:
	BSF GPIO,1
	CALL Delay255
	GOTO OFF
LO:
	BCF GPIO,1
	CALL Delay255
; Delays ============================================================================
Delay255
		movlw	d'255'		; delay 255 mS
		goto	d0
Delay100
		movlw	d'100'		; delay 100mS
		goto	d0
Delay50
		movlw	d'50'		; delay 50mS
		goto	d0
Delay20
		movlw	d'20'		; delay 20mS
		goto	d0
Delay5
		movlw	d'05'		; delay 5ms (4 MHz clock)
d0		movwf	counta
d1		movlw	d'199'		; delay 1mS
		movwf	countb
		movlw	d'01'
		movwf	countc
Delay_0
		decfsz	countb, f
		goto	$+2			; skip two clock cycles
		decfsz	countc, f
		goto	Delay_0
		decfsz	counta, f
		goto	d1			;	once counta and countb have reached zero
		RETLW 0
	END
Heres the Hex file:
clapclap.rar
(274 Bytes) Downloaded 578 times
I have not tested this code but it compiles in MPLAB all ok. And I dont know whether it will support the hardware either!?.
Posted: Thu Aug 16, 2012 11:44 pm
by nodoubtman
bitfogav wrote:This is probably what I would have done.
	cblock 0x09
		counta
		countb
		countc
	endc
INITIALIZE
	CLRF GPIO
	MOVLW B'00001000'
	OPTION
	NOP
	NOP
START:
	CLRF GPIO
WAITADC:
NEXT:
	GOTO HI
OFF:
	MOVWF ADCON0
	BSF ADCON0,GO
WAITADC2:
NEXT2:
	GOTO LO
HI:
	BSF GPIO,1
	CALL Delay255
	GOTO OFF
LO:
	BCF GPIO,1
	CALL Delay255
Delay255
		goto	d0
Delay100
		goto	d0
Delay50
		goto	d0
Delay20
		goto	d0
Delay5
d0		movwf	counta
		movwf	countb
		movlw	d'01'
		movwf	countc
Delay_0
		decfsz	countb, f
		decfsz	countc, f
		goto	Delay_0
		decfsz	counta, f
		RETLW 0
	END
Heres the Hex file:
clapclap.rar
thank you so much! :)
marC:)
Posted: Fri Aug 17, 2012 9:38 am
by nodoubtman
that doesn't seems to work okay, maybe you need the hardware setting :
marC:)
EDITED: by bitfogav*
Posted: Sat Aug 18, 2012 3:35 am
Have you tested your circuit with the two clap programme, Do the circuit work then?.
Posted: Mon Aug 20, 2012 9:00 am
by nodoubtman
bitfogav wrote:Have you tested your circuit with the two clap programme, Do the circuit work then?.
yeah his source code works !
but can you modify it for one single clap with this hardware?
thanks!
marC:)
Posted: Tue Aug 21, 2012 7:32 am
So when you use the two clap programme then everything works correctly??, what happens when you use my programme? Do anything happen when you clap once?.
Posted: Wed Aug 22, 2012 4:29 am
by nodoubtman
bitfogav wrote:So when you use the two clap programme then everything works correctly??, what happens when you use my programme? Do anything happen when you clap once?.
no nothings happens, the led is still on, no reaction of the relay
thanks!
marC:)
