It is currently Fri May 24, 2013 4:09 am
 Post subject: EEPROM and Binary Counter
PostPosted: Mon May 31, 2010 7:23 am
Hey all,
Heres the souce code
http://www.bradsprojects.com/phpBB2/uploads/binary_counting_tutorialv1_174.asm
Binary Counting TutorialV1.asm [8.82 KiB]
Downloaded 51 times
PostPosted: Mon May 31, 2010 7:58 am
Heres the schematics :)
http://www.bradsprojects.com/phpBB2/uploads/eeprom_and_binary_counter_170.zip
Note this schematics is for EAGLE
Eeprom & Binary Counter.zip [13.71 KiB]
Downloaded 104 times
PostPosted: Mon May 31, 2010 8:58 am
What a great project!
I love projects that are quick, to the point, and do something useful. Definitely should become a tutorial!
I did not read through the code but had a quick look and love how nice and clean it is (makes for easy reading). I like to section off my routines just like you did.
I have always wanted to look into programming with eeprom storage. This is my chance!
Thank you.
:D
PostPosted: Mon May 31, 2010 9:07 am
Thanks Stacy :)
The souce code that I have uploaded is a basic start to eeprom and the way it works, you can change the souce code to select different eeprom addresses to store your data, and read your eeprom from your programmer, if you got a pickit2 this is quite easy.
I guess I should make a tutorial for it because before I started looking into eeprom on the microchip I didnt know where to start, took me awhile reading through the datasheet to understand it :)
PostPosted: Mon May 31, 2010 9:25 am
bitfogav wrote:
...before I started looking into eeprom on the microchip I didnt know where to start, took me awhile reading through the datasheet to understand it :)
I know exactly how you feel. I wanted to know about interrupts and could not find any plain and simple answers. Like you, I spent a LOT of time reading through the datasheet, asking questions on the Microchip forum and searching around.
I just wanted a very basic tutorial on how an interrupt works and something so I could see it working. That is why I finally uploaded one to Brad's Projects University. I tried really hard to keep it as simple as possible.
I am excited to go through your code and see how to utilize eeprom in my projects!
PostPosted: Mon May 31, 2010 9:32 am
Yeah thats the thing, I learn more if somebody shows me but all I have is what I learnt from here or reading books or the internet.. :)
Ill be glad to help you if you ever get stuck or have a question about my souce code :)
Ill look forward to see what you come up with..
PostPosted: Mon May 31, 2010 8:36 pm
Nice project :)
This is something I want to implement in my projects - perhaps to save some game data - maybe to save what level you are upto, or maybe a high score or something... hmm...
I have read through the source code and I may have some questions for you later :)
PostPosted: Mon May 31, 2010 8:39 pm
Thanks and yeah sure :)
I have found though that on bigger microchips the setup of eeprom eg, writing and reading from eeprom are slightly different.. :)
PostPosted: Mon May 31, 2010 8:44 pm
Its the same for data tables also.
instead of using retlw instructions, you use tblrd and it is a very different process. The upside is that there is no limit to the amount of data in your table. (only limited by the program memory space of the pic)
PostPosted: Tue Jun 08, 2010 4:19 am
For people who dont know much about eeprom then I recommend looking at this website :)
http://www.arlabs.com/help.htm
