It is currently Wed May 22, 2013 9:39 am
Post new topic Reply to topic  [ 13 posts ]
 Post subject: CLAP CLAP circuit with RELAY OUTPUT
PostPosted: Thu Aug 02, 2012 3:30 am
hi! this is the asm code for a clap clap circuit, but unfortunaly it turns the relay no after two claps, is it possible to make it for one clap ? and can you provide me the code PLEASE for a single clap, thank you sooo much!!!!
marC:)
Code:
; This file is a basic code template for assembly code generation *
; on the PIC10F222. This file contains the basic code *
; building blocks to build upon. *
; Refer to the MPASM User's Guide for additional information on *
; features of the assembler (Document DS33014). *
; Refer to the respective PIC data sheet for additional *
; information on the instruction set. *
; Filename: xxx.asm *
; Date: JULY 17/11 *
; File Version: Rev.A *
; Author: Patrick Mitchell *
; Company: www.engineeringshock.com *
; Files Required: P10F222.INC *
; Notes: *
list p=10F222 ; list directive to define processor
#include <p10F222.inc> ; processor specific variable definitions
__CONFIG _MCLRE_OFF & _CP_OFF & _WDT_OFF & _MCPU_OFF & _IOFSCS_4MHZ
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
;***** VARIABLE DEFINITIONS
TEMP_VAR UDATA
TEMP1 RES 1 ;DELAY REGISTER1
TEMP2 RES 1 ;DELAY REGISTER2
TEMP3 RES 1 ;DELAY REGISTER3
TEMP4 RES 1 ;DELAY REGISTER4
TEMP5 RES 1 ;TIMING REGISTER
TEMP6 RES 1 ;TINING REGISTER
errorlevel -302 ; suppress message 302 from list file
ORG 0xFF ; processor reset vector
; Internal RC calibration value is placed at location 0xFF by Microchip
; as a movlw k, where the k is a literal value.
ORG 0x000 ; coding begins here
movwf OSCCAL ; update register with factory cal value
INITIALIZE
MOVLW B'1000' ; GPIO1=COMPARATOR IN - GPIO0-RELAY ACTIVATE
TRIS GPIO ; INITIALIZE
CLRF ADCON0 ; ADC DISABLE
CLRF GPIO
MOVLW B'00001000'
OPTION
CALL LOOP3
CLRF TEMP5
START:
CLRF GPIO
MOVLW B'01000001' ;analog i/p configuration
MOVWF ADCON0 ;setup GPIO,0 as ADC input
BSF ADCON0,GO ;take an ADC reading
WAITADC:
BTFSC ADCON0,GO ; poll for reading to complete
GOTO WAITADC ; if not done, keep polling
MOVLW B'00000001' ; place 01H in compare register
SUBWF ADRES,C ; compare instruction
BTFSC STATUS,C ; if ADC reading is more than 01H, a clap has been detected
GOTO NEXT ; if clap has been detected, to go NEXT routine
GOTO START ; if not, start from beginning of program
NEXT:
CALL LOOP3 ; delay
GOTO HI
;BCF STATUS,C ; clear STATUS flag so that we can use ADC again
;MOVLW 0XFF ; Place FFH in WREG
;MOVWF TEMP3 ; Place FFH into timing register - Will take the following steps up to 255 times (FF Hex)
NEXT2:
CALL LOOP1 ; short delay
BCF STATUS,C
MOVLW B'01000001' ; analog i/p configuration
MOVWF ADCON0 ; setup ADC
BSF ADCON0,GO ; Take an ADC reading
WAITADC2:
BTFSC ADCON0,GO ; poll for ADC reading to complete
GOTO WAITADC2 ; if not complete, poll again
MOVLW B'00000001' ; repeat same steps in earlier programming to look for second clap
SUBWF ADRES,C
BTFSC STATUS,C
GOTO HI ; if second clap is detected, to go step that turns on relay
DECFSZ TEMP3 ; if not, decrement countdown register and compare with 0
GOTO NEXT2 ; if timing register is not 0, repeat ADC reading
GOTO START ; if timing register = 0, restart program from scratch
OFF:
; the following set of routines follow the same programming as the first half of the program, only
; this time, we're looking for two claps that will turn the relay off
MOVWF ADCON0
BSF ADCON0,GO
WAITADC3:
BTFSC ADCON0,GO
GOTO WAITADC3
MOVLW B'00000001'
SUBWF ADRES,C
BTFSC STATUS,C
GOTO NEXT3
GOTO OFF
NEXT3:
CALL LOOP3
BCF STATUS,C
MOVLW 0XFF
MOVWF TEMP3
NEXT4:
CALL LOOP1
BCF STATUS,C
MOVWF ADCON0
BSF ADCON0,GO
WAITADC4:
BTFSC ADCON0,GO
GOTO WAITADC4
MOVLW B'00000001'
SUBWF ADRES,C
BTFSC STATUS,C
GOTO LO
DECFSZ TEMP3
GOTO NEXT4
GOTO OFF
HI:
; this routine turns the relay on
BSF GPIO,1
CALL LOOP3
GOTO OFF
LO:
; this routine turns the relay off
BCF GPIO,1
CALL LOOP1
GOTO INITIALIZE ; resets system to start from scratch
; *** LOOP1/2 Routines work together as a short delay routine
LOOP1:
MOVLW 0X00
MOVWF TEMP1
MOVLW 0X02
MOVWF TEMP2
LOOP2:
DECFSZ TEMP1
GOTO LOOP2
DECFSZ TEMP2
GOTO LOOP2
RETURN
; LOOP3/4 work together as a long delay routine
LOOP3:
MOVLW 0X00
MOVWF TEMP1
MOVLW 0X30
MOVWF TEMP2
LOOP4:
DECFSZ TEMP1
GOTO LOOP4
DECFSZ TEMP2
GOTO LOOP4
RETURN
END
Code:
 Post subject: Re: CLAP CLAP circuit with RELAY OUTPUT
PostPosted: Fri Aug 10, 2012 3:32 am
Why dont you see if you can change the programme yourself? :)
Ill give you a clue, you might want to remove this part of the code from within the code
Code:
NEXT2:
BCF STATUS,C
WAITADC2:
SUBWF ADRES,C
BTFSC STATUS,C
_________________
PostPosted: Thu Aug 16, 2012 4:38 am
Code:
NEXT2:
BCF STATUS,C
WAITADC2:
SUBWF ADRES,C
BTFSC STATUS,C
i don't know assembly i will try thank you bigof! :)
marC:)
PostPosted: Thu Aug 16, 2012 4:44 am
I guess i will have to remove this part too ?? :
WAITADC3:
BTFSC ADCON0,GO
GOTO WAITADC3
MOVLW B'00000001'
SUBWF ADRES,C
BTFSC STATUS,C
GOTO NEXT3
GOTO OFF
NEXT3:
CALL LOOP3
BCF STATUS,C
MOVLW 0XFF
MOVWF TEMP3
NEXT4:
CALL LOOP1
BCF STATUS,C
MOVWF ADCON0
BSF ADCON0,GO
WAITADC4:
BTFSC ADCON0,GO
GOTO WAITADC4
MOVLW B'00000001'
SUBWF ADRES,C
BTFSC STATUS,C
GOTO LO
DECFSZ TEMP3
GOTO NEXT4
GOTO OFF
thanks!
marC:)
yes? :)
PostPosted: Thu Aug 16, 2012 5:08 am
nodoubtman wrote:
i don't know assembly i will try thank you brad! :)
marC:)
We all had to start somewhere, Brads assembly tutorials are always a good place to start.
Brads Tutorials
WAITADC3:
BTFSC ADCON0,GO
GOTO WAITADC3
MOVLW B'00000001'
SUBWF ADRES,C
BTFSC STATUS,C
GOTO NEXT3
GOTO OFF
NEXT3:
CALL LOOP3
BCF STATUS,C
MOVLW 0XFF
MOVWF TEMP3
NEXT4:
CALL LOOP1
BCF STATUS,C
MOVWF ADCON0
BSF ADCON0,GO
WAITADC4:
BTFSC ADCON0,GO
GOTO WAITADC4
MOVLW B'00000001'
SUBWF ADRES,C
BTFSC STATUS,C
GOTO LO
DECFSZ TEMP3
GOTO NEXT4
GOTO OFF
thanks!
marC:)
yes? :)
Yes you can remove that code aswell but you will need to come up with some code to turn off the relay after it has been activated.
Gavin :)
_________________
PostPosted: Thu Aug 16, 2012 5:23 am
HI:
BSF GPIO,1
CALL LOOP2
GOTO OFF
just put LOOP2 instead LOOP3 , is it okay?
LO:
BCF GPIO,1
CALL LOOP1
here's the full code for one single clap :
; Company: http://www.engineeringshock.com *
; Notes: *
TEMP_VAR UDATA
INITIALIZE
CLRF GPIO
MOVLW B'00001000'
OPTION
CALL LOOP1
CLRF TEMP5
START:
CLRF GPIO
WAITADC:
NEXT:
CALL LOOP2 ; delay
OFF:
MOVWF ADCON0
BSF ADCON0,GO
HI:
BSF GPIO,1
CALL LOOP2
GOTO OFF
LO:
BCF GPIO,1
CALL LOOP1
LOOP1:
MOVLW 0X00
MOVWF TEMP1
MOVLW 0X02
MOVWF TEMP2
LOOP2:
DECFSZ TEMP1
GOTO LOOP2
DECFSZ TEMP2
GOTO LOOP2
RETURN
END
is okay?
thanks!
marC:)
PostPosted: Thu Aug 16, 2012 6:25 am
This is probably what I would have done.
Code:
   cblock 0x09
      counta
      countb
      countc
   endc
INITIALIZE
   CLRF GPIO
   MOVLW B'00001000'
   OPTION
   NOP
   NOP
START:
   CLRF GPIO
   MOVWF ADCON0       ; setup GPIO,0 as ADC input
   BSF ADCON0,GO       ; take an ADC reading
WAITADC:
NEXT:
   CALL Delay255       ; delay
   GOTO HI
OFF:
   ; this time, we're looking for one clap that will turn the relay off.
   MOVWF ADCON0
   BSF ADCON0,GO
WAITADC2:
   GOTO WAITADC2       ; if not done, keep polling
   GOTO NEXT2          ; if clap has been detected, to go NEXT2 routine
   GOTO WAITADC2       ; if not, start from beginning of program
NEXT2:
   GOTO LO
HI:
   BSF GPIO,1
   CALL Delay255
   GOTO OFF
LO:
   BCF GPIO,1
   CALL Delay255
; Delays ============================================================================
Delay255
      movlw   d'255'      ; delay 255 mS
      goto   d0
Delay100
      movlw   d'100'      ; delay 100mS
      goto   d0
Delay50
      movlw   d'50'      ; delay 50mS
      goto   d0
Delay20
      movlw   d'20'      ; delay 20mS
      goto   d0
Delay5
      movlw   d'05'      ; delay 5ms (4 MHz clock)
d0      movwf   counta
d1      movlw   d'199'      ; delay 1mS
      movwf   countb
      movlw   d'01'
      movwf   countc
Delay_0
      decfsz   countb, f
      goto   $+2         ; skip two clock cycles
      decfsz   countc, f
      goto   Delay_0
      decfsz   counta, f
      goto   d1         ;   once counta and countb have reached zero
      RETLW 0
   END
Heres the Hex file:
clapclap.rar [274 Bytes]
Downloaded 21 times
I have not tested this code but it compiles in MPLAB all ok. And I dont know whether it will support the hardware either!?.
_________________
PostPosted: Thu Aug 16, 2012 11:44 pm
Code:
   cblock 0x09
      counta
      countb
      countc
   endc
INITIALIZE
   CLRF GPIO
   MOVLW B'00001000'
   OPTION
   NOP
   NOP
START:
   CLRF GPIO
WAITADC:
NEXT:
   GOTO HI
OFF:
   MOVWF ADCON0
   BSF ADCON0,GO
WAITADC2:
NEXT2:
   GOTO LO
HI:
   BSF GPIO,1
   CALL Delay255
   GOTO OFF
LO:
   BCF GPIO,1
   CALL Delay255
Delay255
      goto   d0
Delay100
      goto   d0
Delay50
      goto   d0
Delay20
      goto   d0
Delay5
d0      movwf   counta
      movwf   countb
      movlw   d'01'
      movwf   countc
Delay_0
      decfsz   countb, f
      decfsz   countc, f
      goto   Delay_0
      decfsz   counta, f
      RETLW 0
   END
Heres the Hex file:
clapclap.rar
thank you so much! :)
marC:)
PostPosted: Fri Aug 17, 2012 9:38 am
that doesn't seems to work okay, maybe you need the hardware setting :
marC:)
EDITED: by bitfogav*
PostPosted: Sat Aug 18, 2012 3:35 am
Have you tested your circuit with the two clap programme, Do the circuit work then?.
_________________
PostPosted: Mon Aug 20, 2012 9:00 am
yeah his source code works !
but can you modify it for one single clap with this hardware?
thanks!
marC:)
PostPosted: Tue Aug 21, 2012 7:32 am
So when you use the two clap programme then everything works correctly??, what happens when you use my programme? Do anything happen when you clap once?.
_________________
PostPosted: Wed Aug 22, 2012 4:29 am
no nothings happens, the led is still on, no reaction of the relay
thanks!
marC:)
