It is currently Sun May 19, 2013 10:49 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: http://www.sureelectronics.net/goods.php?id=230
PostPosted: Fri May 11, 2012 10:31 pm
Offline
Hi Brad! I have ordered these, but it shows that it's only green dot , is it normal? maybe it's the connection?..
i have perfectly followed the schematic on the great race??
thanks!
marC:)
Top
 Profile E-mail
 Post subject: Re: http://www.sureelectronics.net/goods.php?id=230
PostPosted: Sat May 12, 2012 2:45 am
Offline
Quote:
10pcs 8x8 Dot-Matrix 3mm dia. Bicolor LED Display (LE-MM103)
No they are the Bicolour ones, so I would double check your connections?. But note that the Great Race schematic only uses the lower Red Row of LEDs.
Top
 Profile
PostPosted: Sat May 12, 2012 4:31 am
Offline
and your smile does use red dot too?
how can i check the color of each dot ?
thanks!
marC:)
Top
 Profile E-mail
PostPosted: Sat May 12, 2012 5:04 am
Offline
All the information you will need about the 8x8 matrix is at the link below, I suggest you read through the topic and then you will get a better understanding on how the 8x8 Matrix works.
http://www.bradsprojects.com/forum/viewtopic.php?f=2&t=250&start=0
Top
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Theme made by Keenen Wheeler
