Hello! Which 8x8 dot matrix would be good for these projects, would : http://www.ebay.ca/itm/10pcs-8x8-Dot-Ma ... 35b6bc78b3
would be good?
thank you!
CA or CC ?
thank you all!
marC:)
which 8x8 dot matrix, is this one good ?
- Joined: Wed Jan 25, 2012 2:54 am [phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Re: which 8x8 dot matrix, is this one good ?
Hi Marc,
Yes those 8x8 led matrix's are what you need, mine are from sure electronics
Those ones will certainly do the job although I do recommend getting the diffused ones. They just look so much nicer.
these ones are good ?brad wrote:Those ones will certainly do the job although I do recommend getting the diffused ones. They just look so much nicer.
http://www.ebay.ca/itm/20x-BULK-LOT-LED ... 27c412765c
thank you!
marC:)
Those ones are the small 2cm x 2cm versions which I am very sure would only be one color (red) as opposed to having red and green in them.
Hi Brad!brad wrote:Those ones are the small 2cm x 2cm versions which I am very sure would only be one color (red) as opposed to having red and green in them.
I have just got 8x8 matrix bicolor 3 mm from sure electronic : XSM-D1088BRG, but the only problem that it has 12 pins not 8 pins...
how do i interface them for smiley face animation you have created?
thanks so much!
marC:)
Try this topic, you should find what you are looking for here:
viewtopic.php?f=2&t=250
Gavin AKA Bitfogav
Gavin AKA Bitfogav
